DC jack wiring
DC jack wiring
Postby javimart1212 » 20 Jul 2019, 09:35
So I rehoused a Boss DS 1 to a new 125B enclosure and made it true bypass,but I think Im having problems with the DC jack. What is the correlation from the PCB mounted DC jack to the round barrel type DC Jack? This is probably very easy to most, but I'm not the most experienced modder so, as always, Im super appreciative of anyone who can help me out. Thanks
javimart1212
Re: DC jack wiring
Postby phatt » 20 Jul 2019, 12:10
I'm not clear on what the pictures mean but If you are using the Metal chassis type and mounting it directly to the metal case then you would be dead shorting the supply.
Remember that the Centre pin is Neg (Common/Ground) and outer sleeve is Positive/Hot +9Volts.
You can use your meter to find out what the tabs connect to,, the centre pin should be easy to work out but the sleeve is switched between the other 2 tabs so when you insert the plug those 2 tabs Disconnect.
Phil.
phatt
Have thanks: 273 times
Re: DC jack wiring
Postby javimart1212 » 20 Jul 2019, 18:40
sorry for not being clear, I was just wondering which pins on the pcb mounted are the pins on the chassis type one. for example sleeve on mounted = blue on chassis type?
javimart1212
Re: DC jack wiring
Postby phatt » 21 Jul 2019, 11:00
This test assumes the power you are using is Centre Neg.
Using a bare socket, plug in the power.
Set DMM to Volts DC, Now with black Neg probe on centre pin, then one of the other 2 tabs should give you +9Volts.
The remaining tab will read zero.
The zero tab will be for the +battery connection.
The Centre pin should be fairly obvious as it's usually directly in line with the centre pin and likely has a rivet holding the tab.
Hope that helps.
Phil.
phatt
Re: DC jack wiring
Postby javimart1212 » 22 Jul 2019, 03:15
thanks for the help... I figured it out. [smilie=rlp_smilie_242.gif]
rehoused true bypass DS 1 .... Keeley mods are next
javimart1212
Users browsing this forum: aionios, kmc212, znevex and 7 guests
