Rockman loop schematic
Postby okgb » 20 Jan 2011, 22:13
In case anyone needs it , i found this
that i had done years ago [ should be correct ]
get a volt or so of power from the Rockman octopus midi unit
[ 8 funtion switches ] Cheers -Greg
okgb
Has thanked: 209 times
Have thanks: 43 times
Re: Rockman loop schematic
Postby Shawnee » 07 Oct 2013, 04:00
Hey guys, I am trying to make a couple of loop boxes for my old Rockman Octopus. I hooked up my Octopus and checked a loop for output voltage when the loop is on and I get 4.2vdc from tip to ring on the stereo 1/4" output. I put the 4.2vdc across the coil of my relay (Fujitsu RY-5W-K) and it would not energize. I checked the relay on my trusty power supply and even at a little under 4v, it will energize. Any suggestions?
Shawnee
Have thanks: 7 times
Postby okgb » 01 Dec 2013, 16:00
A friend has one [ for sale ] here are the actual pix, let me know if you need more while I have it.
[ how do you post them so they don't disappear ? ]
For this message the author okgb has received thanks:
Shawnee (01 Jan 2014, 16:11)
okgb
Postby okgb » 01 Dec 2013, 17:31
Red wire is the tip on the captive cord [ which goes to octopus unit ] white is the ring.
resister is 100k [ measured 92k IN circuit ] cap is 220 uf 16v .
Activating a loop on the octopus appears to put .6 volts from tip to ground , de-activating it
switches the .6 v to ring to ground
okgb
Postby Shawnee » 01 Jan 2014, 16:12
Oh man I'm sorry, I just saw this. THANK YOU so much.
Shawnee
Postby ssimm1958 » 04 Jan 2014, 14:00
unless the wiring was different in older loops, i think i saw a mistake in the wiring at the input send return and output jacks on the drawing in this post, and the relay part number is different also than whats in my loops, so heres my drawing and notes, hope helps out you guys, if see any mistakes let me know,, thanks....steve
ssimm1958
Postby ssimm1958 » 04 Jan 2014, 14:09
also just wondering if anybody knew of a replacement relay for the Aromat DR-C-5V used in the rockman remote loops because these relays were discontinued?
ssimm1958
Postby Wile.E » 13 Sep 2019, 23:06
Does anyone still have the schematic for this?
Wile.E
Postby okgb » 16 Sep 2019, 22:19
Check the differences between the two above, mine was as I saw it from a rockman loop box, but the basic idea is there
okgb
Users browsing this forum: Google [Bot], McOmio, opa and 9 guests
