EHX - Deluxe Memory Man (SAD 1024A) EH7550  [schematic]
bunyaman
Post by bunyaman »
rasta_maleek
Has thanked: 52 times
Been thanked: 52 times
Post by rasta_maleek »
I buy (150€) deluxe memory man vintage( I think reissue) I will inner photos if you want it, it has build in transformer.
starkjo
Post by starkjo »
Resurrecting an old thread here. Does anyone have the schematic and/or possible service manuals etc. for the EC2002_REV_E Deluxe Memory Man? If possible, PM me or mail me at starkjo@gmail.com . I'd appreciate it a lot!
Another noob question - in some pics in this thread, the MN3008 chips have the number 7 on them, while mine have the number 3 (in addition to "MN3008" and "0.0"). What do the 7s or 3s mean?
Has thanked: 232 times
Been thanked: 887 times
The 4*3008* schem can be found here:
http://music-electronics-forum.com/t25604/
starkjo
Post by starkjo »
Thanks a bunch, Dirk! Really appreciate it.
I'm gonna go thru it to see if there are any changes from the schematic you pointed out, to my REV_E board, but if there turn out to be any changes, they'll probably be minor.
Great stuff.
A board revision does not necessarily mean a schem revision as well. Considering the DMM design is rather old chances on dramatic circuit changes are really small.
gonziak
my favorite amplifier: Deluxe Reverb, Tweed Deluxe
Completed builds: Jtm 45/100 marshall clone, Box of rock, tube reamer, Deluxe reverb rebuilt, Tweed deluxe head + cab 4*10"
Post by gonziak »
guiltyspark wrote:I have one of these memory man RI's also, I like it a lot. Mine also clips with just about any guitar. I found this post on another forum and have been meaning to try it, any comments?
Now, the stock input impedence is really low and there's a ton of potential gain on tap - much more than is needed, even using the DMM as a boost. So replace the 100K resistor in the input with a 1M pot. Here's the schematic: http://www.freeinfosociety.com/electron ... php?id=381.
The stock gain structure has a 100K resistor before the opamp and a 1M pot in the feedback loop (this is the volume pot). By changing the 100k resistor to a 1M pot, you can set it to the stock impedance and when the volume pot is on full, have 10x gain. But you don't need 10x gain, and the stock impedance is really low and loads down the pickups in a passive guitar (particularly with single coils). Put in the 1M pot and you can raise the input impedance and lower the overall gain available, finding a balance between a higher input impedance and still having enough gain on tap. I liked the input pot set to about 500K, which still had enough gain (2:1 at max though I didn't use it on max) for a nice boost. Really improved the sound and gave it more depth.
Guiltyspark
Thanks a lot. :thumbsup I changed the 100K to 470K resistor. No problem with big muff volume drop. It's before The DMM.
guiltyspark
Been thanked: 39 times
Post by guiltyspark »
Old post! I had cut and pasted this DMM info from somewhere on the net, glad to hear it works. I still have my RI DMM, maybe I'll try this mod.
starkjo
Post by starkjo »
Hey all,
is the schematic for the ~1990s DMM version available? I'm referring to the one with two MN3005 chips and the Pico HB board.
Dragaman
Post by Dragaman »
Hey guys my roommates dog sharted, yes took a dump, on my momery man that I modded perfectly with vintage components. If anyone would be so kind to let me know what resistance the vcc is, after the voltage regulator, to ground. I would be greatly appriciative! FYI I have the relay version
OrionManMatt
my favorite amplifier: AC30
Completed builds: BB Preamp, volume pedals, tap tempo boxes, etc.
Been thanked: 16 times
Post by OrionManMatt »
Is there anyone that has posted an analysis of the DMM? I've been interested in learning more about how it all works.
For instance, I stumbled onto this page a week ago or so and, comparing it with the DMM schematic and attempting the math, calculated the two frequencies in the DMM's LFO (chorus: 0.946 Hz; vibrato: 4.432 Hz).
http://www.electrosmash.com/boss-ce-2-analysis
What I'm less skilled at is figuring out the math for the depth in the LFO, or for other sections in the pedal (e.g., filters). Any advice?
bengke
Post by bengke »
where can i find the EHX DMM XO schematic? it has 4x MN3008
I can't download the schematic from above link :slap:
Thanks :popcorn:
espflash
Been thanked: 11 times
Post by espflash »
Hello!
I need a PCB of https://www.freestompboxes.org/viewtopic ... 20#p117656
Anybody have?
Bernardduur
Has thanked: 94 times
Been thanked: 732 times
Post by Bernardduur »
analogguru wrote:In that other forum somebody is searching for these schematics, here they are:
https://img.photobucket.com/albums/v317 ... eluxe2.jpg
https://img.photobucket.com/albums/v317 ... eluxe1.jpg
https://img.photobucket.com/albums/v317 ... eluxe3.jpg
I have one of these units in for some little work. A lot of HUMMMMM, bad ELCO's and more.
The schematics are readble but then again a little bit sketchy. I'm tracing this one.
The only thing that bothers me is the item next to IC5b, right after the cap, there is a 130k resistor with something in parallel. WHAT IS THAT???? I'll make a picture of it; I can't really see what it is.........
Bernardduur
The schematic says "JP5W1" that yields no match
Scruffie
Has thanked: 28 times
Been thanked: 170 times
Post by Scruffie »
It's a thermistor.
Bernardduur
Scruffie wrote:It's a thermistor.
OK.... why use a thermistor on this place?
Scruffie
Post by Scruffie »
Shits & Giggles?
I guess they expected some temperature variation (transformer heat?) and wanted to make sure the gain didn't drift.
Bernardduur
The schematic:
Bernardduur
This unit works perfectly but I have an audible whine that decreases in frequency when the delay time is enlarged.
Is there a way to eliminate this? Would adding a balance trimpot to all the SAD's help?
