Boss - PH-1r ( Phaser )  [schematic]
Postby R.G. » 18 Dec 2007, 23:16
The Boss PH-1r schematic is now up at GEO (http://www.geofex.com).
Many thanks to those who helped and offered help in extracting this one. In the end it was a combination of top/bottom shots from the net and the gracious assistance of Ry Hoffman that got this done.
For this message the author R.G. has received thanks:
modman (15 May 2012, 20:41)
R.G.
Have thanks: 41 times
Postby seniorLoco » 19 Dec 2007, 02:45
Nice one...thanks RG.
seniorLoco
Have thanks: 10 times
Re: Boss PH-1r Phaser
Postby modman » 22 Jul 2008, 15:14
Some pictures:
Has thanked: 2959 times
Have thanks: 520 times
Postby Dirk_Hendrik » 23 Jul 2008, 16:59
I know it's an older post but nevertheless RG's work enabled me to fix one of these in some 15 minutes. Thanks RG!
Has thanked: 250 times
Have thanks: 995 times
Postby PmCimini » 17 Aug 2008, 08:39
first boss pedal i see that uses 4558 instead of their trademark M5218. hah, interesting
PmCimini
Has thanked: 24 times
Have thanks: 3 times
Re: Boss - PH-1r ( Phaser )
Postby KHELSTROM » 23 Mar 2009, 21:31
Does anyone have a schematic for the original 2 knob version PH-1? I have one in for a repair.
KHELSTROM
Have thanks: 6 times
Postby R.G. » 24 Mar 2009, 18:37
KHELSTROM wrote:Does anyone have a schematic for the original 2 knob version PH-1? I have one in for a repair.
No, but a few good high res photos of the component and trace side of the board and answering a few component questions would get it for you.
R.G.
Postby Ry » 25 Mar 2009, 03:45
I have a schematic, layout, and calibration data for the PH-1. I don't have an easy means to post it, if someone contacts me, I will gladly email these for posting somewhere.
Ry
For this message the author Ry has received thanks:
x-tn (24 Apr 2011, 15:06)
Ry
Postby borislavgajic » 26 Mar 2009, 16:40
Thanks Ry..... :thumbsup
boris
For this message the author borislavgajic has received thanks: 3
DJGlukBH (01 Aug 2013, 11:31), electrosonic (27 Jan 2011, 08:40), x-tn (24 Apr 2011, 15:06)
borislavgajic
Has thanked: 137 times
Have thanks: 240 times
Postby lynessmy » 02 Feb 2010, 11:36
Not sure how this is gonna help. Just want to share what is on my hand.
These photos are snapped from MIJ - Jan 84's. (SN:389400).
Slightly different chips brand compared the the earlier units as shared by modman.
High resolution image can be email upon request (~4.4M per pcs).
Enjoy.
lynessmy
Postby salocin » 02 Feb 2010, 11:55
Excellent quality pics! :thumbsup
salocin
Postby pedalist » 05 Feb 2010, 12:36
Is boss ph-1r pcb available, please?
pedalist
Have thanks: 2 times
Boss PH-1 phaser gutshots
Postby Nocentelli » 03 Jan 2011, 16:29
Found these on Bossarea:
mmolteratx wrote:absolutely zero commercial use allowed. If I find anyone selling these, I'll fly to your house and kick you in the nads. And you may or may not find yourself in trouble.
modman (15 May 2012, 20:40)
Nocentelli
Has thanked: 813 times
Have thanks: 819 times
Re: Boss PH-1 phaser gutshots
Postby electrosonic » 03 Jan 2011, 17:32
I have one of these open on my workbench if anyone wants more pics. Mine only works while the footswitch is held down, so I am tracing out the flip flop area.
Andrew.
electrosonic
Has thanked: 28 times
Have thanks: 19 times
Postby recontravintash » 26 Jan 2011, 20:13
Hey! I want to make a copy of this pedal, I'm thinking about put it into a hammond-type enclosure... so my question is, what's the size of the PCB? which hammond-like box would fit to the pcb?
recontravintash
Postby Duckman » 26 Jan 2011, 21:40
recontravintash wrote:so my question is, what's the size of the PCB?
It's a Boss pedal... What you think? :lol:
Duckman
Has thanked: 364 times
Have thanks: 125 times
Postby recontravintash » 27 Jan 2011, 04:06
:hmmm:
oK, it's time to open for first time a boss pedal, not for having to guess that much :D
recontravintash
Postby fuzzbuzzfuzz » 23 Apr 2011, 06:25
Nice post guys - some great info on a great sounding pedal! :D
I recently picked up a PH-1 - but it has a fault which I`m hoping to fix with a little help ;)
Simply put is that when either on or off the signal running through has an element of distortion noise, esp when I twang a low E. Its a fuzzy buzzy noise, not over the top but strong enough to be noticed. If I play softly its ok, but otherwise pretty useless as it ruins the bypass signal and phased signal.
Any ideas? I`ve resoldered the AC jack connections and given the jacks a clean. A suggestion has been a dry Cap somewhere. Can I find and isolate with a multimeter? (excuse my technical ignorance! :oops: )
Would love to get this one working again, any help is really appreciated!
Gut shots on here: http://fuzzbuzzfuzz.blogspot.com/2011/02/boss-ph-1-phaser.html
fuzzbuzzfuzz
Postby blackbunny » 25 Apr 2011, 04:01
fuzzbuzzfuzz wrote:Simply put is that when either on or off the signal running through has an element of distortion noise, esp when I twang a low E. Its a fuzzy buzzy noise, not over the top but strong enough to be noticed. If I play softly its ok, but otherwise pretty useless as it ruins the bypass signal and phased signal.
If it's a PH-1 phaser, it will distort when used with a high output pickup. Boss changed the gain structure inside the pedal so that the later PH-1r has a voltage-dividing stage that halves the signal level being phased by the JFET's, and boosts the signal back up again at the output.
My PH-1 sounds exquisite with "vintage" style single coils or low-output humbuckers, but has a buzzy / farty low frequency distortion with high output pickups. My PH-1r sounds cleaner and slightly brighter, but will still distort with a big chord smash from a high output pickup.
You might be better off looking for a PH-1r, unless you use very high output pickups, in which case it might be best to look for a phaser that doesn't use JFET's.
For this message the author blackbunny has received thanks:
fuzzbuzzfuzz (10 Jun 2011, 11:02)
blackbunny
Has thanked: 239 times
Have thanks: 109 times
boss PH-1r pcb
Postby pedalist » 09 May 2012, 17:32
Hi all I'm looking for boss ph-1r pcb and layout that have send?. Thanks
pedalist
Next
Users browsing this forum: eggman, Google Feedfetcher and 6 guests
