Joyo - JF-07 Classic Flanger  [schematic]
Postby rocklander » 02 Jul 2011, 05:23
arrived ex dhgate yesterday. not played it yet (got practice tomorrow so will then) but here's the shots of it...
happy to take more detailed ones if anyone can suggest which angles they want etc.
For this message the author rocklander has received thanks: 6
culturejam (02 Jul 2011, 05:48), IvIark (08 Jul 2012, 01:31), modman (14 Jun 2012, 12:05), pedalgrinder (28 Jun 2012, 14:18), ppluis0 (03 Jul 2011, 17:25), raindog (03 Jul 2011, 09:24)
rocklander
Has thanked: 1580 times
Have thanks: 289 times
Re: JOYO classic flanger
Postby jrod » 02 Jul 2011, 18:06
I'm kind of hoping this is a copy of the old MXR flanger!
jrod
Has thanked: 331 times
Have thanks: 41 times
Postby lolbou » 02 Jul 2011, 18:29
Are the BBDs Cool Audios? Be careful with the switch wiring : these are likely to break... :wink:
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
Has thanked: 352 times
Have thanks: 240 times
Postby Steven_M » 02 Jul 2011, 19:30
Those Bucket Brigade chips don't look like Cool Audio chips. Are they sanded or just old?
Steven_M
Has thanked: 71 times
Have thanks: 35 times
Postby Fender3D » 02 Jul 2011, 20:09
jrod wrote:I'm kind of hoping this is a copy of the old MXR flanger!
nope it looks like a couple MN3xxx - MN 31xx BBD and clock
nothing to do with 4013 + trannies 8)
Fender3D
Has thanked: 100 times
Have thanks: 134 times
Postby Dirk_Hendrik » 02 Jul 2011, 21:46
I suspect using some Boss and Ibanez schems will give easier reference for quick tracing. Definitely an mn like BBD-Driver combo. Since it's from Tsjai-Nah it might be Bellings in which case a BL3207 is the BBD choice. not a BL3208. Way to long for flanging.
Has thanked: 255 times
Have thanks: 1029 times
Postby Dirk_Hendrik » 02 Jul 2011, 21:48
Steven_M wrote:Those Bucket Brigade chips don't look like Cool Audio chips. Are they sanded or just old?
Rather cynical isn't it? The greatest copycat nation, China, doing sanding to avoid copycats :applause:
Postby rocklander » 02 Jul 2011, 22:32
I knew I should've written down what they were, but assumed that cos I could read them the photo would capture that too...
...but it didn't :slap:
I don't think they're sanded.. maybe a black vivid marker on them? but still legible in daylight
they were CD(something) IIRC... which I thought was odd.. will pull it apart today again (cancelled practice cos I'm far too hungover :lol: ) and note what they are.
how do I tell if they're panasonic? or was that some sort of ironic humour and not important?
rocklander
Postby rocklander » 03 Jul 2011, 07:05
added pic with values of caps and semiconductors.
coudn't read the diodes and don't really wanna desolder it if I don't need to (my soldering work desk is put away at the moment)... is it important enough information to do that, or can some smarter type people make the call as to what they are?
rocklander
Postby GuitarlCarl » 03 Jul 2011, 15:09
That's just WONG... :blackeye
GuitarlCarl
Has thanked: 69 times
Have thanks: 31 times
Postby culturejam » 03 Jul 2011, 17:16
Or maybe they are just copying American boutqiuers who sand the chips? :lol:
culturejam
Has thanked: 466 times
Have thanks: 584 times
Postby ppluis0 » 03 Jul 2011, 17:25
Hey guys,
Pay attention that this pcb have a ground plane at both sides in the area remanent of those that is occupied by the connecting tracks, pads, etc.
This is done in order to reduce noise and parasitic couplings when the unit is running.
Also the manufacturer of the boards prolong the life of the etching solution as there is less copper to take away, so the cost of each boards will be cheaper.
Rocklander, my best guess is that J. Wong hasn´t put any novel solution in this design (perhaps true bypass?), so as Dirk suggest try to compare against the classic designs of Boss and Ibanez flangers.
May be risky to try unsolder any component due the posibility to damage on any thru hole.
ppluis0
Has thanked: 43 times
Have thanks: 87 times
Postby uncleboko » 03 Jul 2011, 17:45
De que parte de Argentina sos?
uncleboko
Has thanked: 55 times
Have thanks: 21 times
Re: JOYO classic flanger  [schematic]
Postby tube-exorcist » 03 Jul 2011, 18:47
The Ibanez FL9 schematic should do the trick.
tube-exorcist
Has thanked: 210 times
Have thanks: 77 times
Postby iq01221 » 03 Jul 2011, 19:18
uncleboko wrote:De que parte de Argentina sos?
:shock: Lots of argentinian diyer, everywhere!!! :secret: (I'm argento too)
iq01221
Has thanked: 35 times
Have thanks: 10 times
Postby ppluis0 » 03 Jul 2011, 21:35
Already sent pm to my connationals... 8)
ppluis0
Postby pedalgrinder » 14 Jun 2012, 12:04
so has there been a verdict on what this pedal has been cloned or based on?
pedalgrinder
Has thanked: 203 times
Have thanks: 154 times
Postby BaldPaul » 08 Jul 2012, 02:39
Can't say what this is a clone of but it replaced an EVH mxr flanger on my board. There was no comparison, My mxr is noisey as all hell and the joyo is not. Sounds exactly the same IMO but with very little noise. The paintjob has got to go though!
BaldPaul
Has thanked: 10 times
Postby drbob1 » 08 Jul 2012, 16:15
I played it back to back with my EVH and the EVH will likely be going down the road. They sound so close that I have to say it's a sonic clone if not a circuit clone. Very decent box for a remarkably small price (got it for a 4 for $34 each deal). The only problem is that I think they're phasing out (not flanging out) the metal box pedals in favor of the lumpy plastic ones...
drbob1
Have thanks: 47 times
Postby atreidesheir » 12 Jul 2012, 22:47
BaldPaul wrote:Can't say what this is a clone of but it replaced an EVH mxr flanger on my board. There was no comparison, My mxr is noisey as all hell and the joyo is not. Sounds exactly the same IMO but with very little noise. The paintjob has got to go though!
I have tried almost all the joyo pedals. None are noisy. NONE.
atreidesheir
Has thanked: 452 times
Have thanks: 43 times
Next
Users browsing this forum: brokenbones and 5 guests
