Griffin MT-2 Death Metal Mod
Postby Seven64 » 06 Oct 2011, 19:45
So I play alot of death metal, and have been looking for a tone similar to the 5150 but not having to spend the coin. I ran across this mod one day, and just had to have it.
Link
I ordered it right away, and found myself a metal zone on craigslist.
Well, I got the mod kit, and was HIGHLY disappointed that I was not going to replacing any of the IC's in the pedal. It also irked me that I had spend over $35 on parts that could be had for much, much cheaper.
I was so disappointed in fact, that I am spilling this $30 mod kit, because the 2nd time around it cost me under $5.
-Replace the limiting Diodes with 3mm LED's (D3 and D4)
-Remove C25 and C35, do not add jumpers
-Replace R14 with a 46k resistor
-Replace R41 with a 680r resistor
**the kit came with 1% metal film 1/4w resistors, not sure if that makes a difference or not.
-Replace C17 with a 1uf Panasonic Multilayer Film Cap (105)
-Replace C36 with a .068uF Panasonic Multilayer Film Cap (683)
-Replace C42 with a .1uF Panasonic Multilayer Film Cap (104)
**the rest of the caps are basic ceramic non polarized caps
-C10 and C18 with 101's
-C26 and C32 with 221's
-C22 and C28 with 121's
And that is the entire mod. 9 caps and 2 resistors.
More recently he included his "noise reduction mod" which I assume helps with the removal of the limiting diodes.
All it is is 2 1n60p diodes facing opposite directions twisted to each other and then bridged between 2 lifted leads from the negative leg of C27 and the leg of R33 that is closest to IC4.
For this message the author Seven64 has received thanks: 2
culturejam (06 Oct 2011, 19:50), tonight, we ride (06 Oct 2011, 22:21)
Seven64
Have thanks: 7 times
Re: Griffin MT-2 Death Metal Mod
Postby tonight, we ride » 06 Oct 2011, 22:20
Thanks Seven64! I've definitely got a MT-2 sitting on a shelf somewhere collecting dust. Gonna have to try this one out for sure!
tonight, we ride
Has thanked: 41 times
Have thanks: 14 times
Postby drbob1 » 12 Oct 2011, 17:36
So, how do you feel about the sound of it before/after? Is the mod really worth it?
drbob1
Have thanks: 47 times
Postby drbob1 » 12 Oct 2011, 17:41
Sorry, I thought the demo was fairly useless as the modded pedal was significantly louder than the unmodded, which is going to change the apparent tone a lot...
drbob1
Postby Seven64 » 12 Oct 2011, 18:08
drbob1 wrote:Sorry, I thought the demo was fairly useless as the modded pedal was significantly louder than the unmodded, which is going to change the apparent tone a lot...
i think that is from removing the limiting diodes and replacing them with LED's.
IMO its alot more crisp of a pedal, and after i swapped out a few more components and switched the IC in the distortion circuit with an OPA2134 it is a very harsh, crispy pedal
Seven64
Postby Seven64 » 17 Oct 2011, 21:58
so i am going off the deep end, and trying to turn this into kinda my own design. im eliminating the whole switching circuit, swapping op amps and trannys, and also eliminating the mids section. thinking about adding a tone control.
here is where it is starting at:
http://www.diystompboxes.com/smfforum/i ... ic=94257.0
Seven64
Postby Lithium_Grim » 30 Jul 2016, 18:11
Do you have some pictures of the pcb after all modifications? That would be great!!
Lithium_Grim
Has thanked: 16 times
Return to Pimp-My-Cheap-Pedal
