EHX - Riddle QBalls VCF
Postby uncleboko » 25 Oct 2011, 15:56
Any clues as to whether an OTA or opamp VCF is used?
uncleboko
Has thanked: 55 times
Have thanks: 22 times
Re: EH Riddle QBalls VCF
Postby uncleboko » 26 Oct 2011, 07:56
And any guesses as to how tthe envelope generator is made up - it does sound very very good, and the slow sweep sounds as smooth as the Space Drum decay :D
uncleboko
Postby uncleboko » 28 Oct 2011, 07:49
Maybe something will surface eventually.
uncleboko
Postby uncleboko » 29 Oct 2011, 14:02
A youtube to circuit diagram function might be useful :cry:
uncleboko
Postby uncleboko » 09 Nov 2011, 16:21
A blank!
uncleboko
Postby uncleboko » 10 Nov 2011, 11:47
I'm wondering if they use a new in house IC for the VCF or whether a stash of CA3094s has been uncovered :hmmm:
uncleboko
Postby uncleboko » 11 Nov 2011, 13:57
uncleboko wrote:I'm wondering if they use a new in house IC for the VCF or whether a stash of CA3094s has been uncovered :hmmm:
:hmmm: :hmmm: :hmmm:
uncleboko
Postby R.G. » 12 Nov 2011, 22:40
The LM13600, LM13700, CA3280, and NE5517 are all closely equivalent in function to two CA3094s in a single DIP. There are differences in the Iabc input and the pre-distortion diodes as well as lower overall noise. Takes a bit of circuit adaptation, but not much.
For this message the author R.G. has received thanks:
modman (29 May 2015, 23:41)
R.G.
Have thanks: 41 times
Postby uncleboko » 15 Nov 2011, 16:04
R.G. wrote:The LM13600, LM13700, CA3280, and NE5517 are all closely equivalent in function to two CA3094s in a single DIP. There are differences in the Iabc input and the pre-distortion diodes as well as lower overall noise. Takes a bit of circuit adaptation, but not much.
This really is a riddle :lol: :lol: :lol:
uncleboko
Postby earthtonesaudio » 15 Nov 2011, 17:00
Is there some reason to assume this is an analog pedal?
earthtonesaudio
Has thanked: 17 times
Have thanks: 109 times
Postby uncleboko » 15 Nov 2011, 17:31
Because it sounds analog.
uncleboko
Postby Scruffie » 15 Nov 2011, 17:40
Quick Specs
80 Hz to 5 kHz frequency response tailored for guitar
Optional expression pedal control
Fully-analog circuit
Switch selectable analog distortion designed for guitar
Start and Stop sweep control
Low Pass, Band Pass, High Pass filter select
Start and Stop for filter sweep and Q control
Separate Dry and Effect outputs
9.6VDC 200mA power supply included
So yeah, it is analog.
LM13700 Based Envelope Filter I guess, they seem to use them alot now... no clue about the detection.
Scruffie
Has thanked: 28 times
Have thanks: 144 times
Postby uncleboko » 15 Nov 2011, 19:34
How are they doing the start & stop frequency envelope generator I wonder?
uncleboko
Postby earthtonesaudio » 16 Nov 2011, 01:45
Scruffie wrote:So yeah, it is analog.
Aha! I didn't scroll down enough on the EHX page, obviously. :slap:
earthtonesaudio
Postby Scruffie » 16 Nov 2011, 01:51
Haha, I assumed it was digital myself, I just happened to catch that in the specs.
Easily done.
Scruffie
Postby Ice-9 » 16 Nov 2011, 12:23
Could be a clue in this picture.
Ice-9
Has thanked: 143 times
Have thanks: 367 times
Postby uncleboko » 16 Nov 2011, 12:27
Am I seeing + and - 9v at the top?
uncleboko
Postby Ice-9 » 16 Nov 2011, 13:24
uncleboko wrote:Am I seeing + and - 9v at the top?
No it looks more like 9v centre negative logo to me.
Ice-9
Re: EHX - Riddle QBalls VCF
Postby uncleboko » 08 Sep 2016, 17:14
Amazing that no circuit has surfaced after all this time!
uncleboko
Postby Ice-9 » 09 Sep 2016, 22:40
uncleboko wrote:Amazing that no circuit has surfaced after all this time!
Did you not see my post above where I circled in black a clue. :secret:
Ice-9
Next
Users browsing this forum: vilenjak and 6 guests
