Guyatone - TD-1 Tube Distortion  [schematic]
ppluis0
Has thanked: 127 times
Been thanked: 299 times
Post by ppluis0 »
Manfred wrote:I traced the TD-1 a couple of years ago.
Now I found the images on my Database.
http://postimg.org/gallery/1ta9mcadg/
Hi Manfred, and best wishes for 2.019 !!!
Can you repost the schematic of this unit ? Look as the link it's no longer valid.
karul
Has thanked: 600 times
Been thanked: 259 times
Post by karul »
schematic and gutshot
ppluis0
Post by ppluis0 »
Thanks pal !!!!!! 8)
Has thanked: 1675 times
Been thanked: 1360 times
Post by Manfred »
Hi Manfred, and best wishes for 2019!!!
Hi Jose, best wishes for 2019 for you too.
The schematic above is not entirely correct, that's is my traced one.
My shots of it:
TD1 Shots.zip
(580.28 KiB) Downloaded 124 times
I made a PCB copy as follows:
Ready to print files of the PCBs:
Guyatone TD-1 Component Side.pdf
(9.19 KiB) Downloaded 141 times
Guyatone TD-1 Solder Side.pdf
(12.62 KiB) Downloaded 115 times
Guyatone TD-1 Solder Side Mirrored.pdf
(12.65 KiB) Downloaded 125 times
Guyatone TD-1 PSU Component Side.pdf
(4.59 KiB) Downloaded 132 times
Guyatone TD-1 PSU Solder Side.pdf
(2.05 KiB) Downloaded 133 times
Guyatone TD-1 PSU Solder Side Mirrored.pdf
SprintLayout6-Files:
TD1_SprintLayout6Files.zip
(17.91 KiB) Downloaded 134 times
karul
Post by karul »
I might be wrong - the only significant difference I can spot is the cathode bypass capacitor 22u/25V at the input stage.
Post by Manfred »
karul wrote:I might be wrong - the only significant difference I can spot is the cathode bypass capacitor 22u/25V at the input stage.
The connections of the gain pot are wrong too.
karul
Post by karul »
Yes. The gain pot too, I was too tired yesterday. Thanks.
ppluis0
Post by ppluis0 »
Hi folks,
Touring on the web I find a schematic related to this subject: Guyatone/Nady TO-2:
