Lehle Sunday Driver  [schematic]
Lehle Sunday Driver
Postby kusi » 21 Mar 2017, 11:09
hello my friends,
long time no see, i hope everyone is still alive and doing great? :D
i just spent some minutes tracing the lehle sunday driver, a great sounding buffer / booster which i use in the studio all the time to track guitar di's (instead of the interface/preamp hi-z in).
nothing too special. the power-supply is a bit strange, it's not the best idea to power a 9v linear regulator with 7,5V imho. also the bias-offset of 0,125V, not sure if it's really worth the effort.
let me know what you think!
cheers,
kusi
For this message the author kusi has received thanks: 6
EdJ (25 Jul 2017, 19:55), lohstah (22 Mar 2017, 09:37), modman (05 Apr 2017, 21:42), plesur (01 Jun 2018, 11:37), rcustoms (26 Mar 2017, 21:42), thpmink (27 Apr 2017, 10:00)
kusi
Have thanks: 39 times
Re: Lehle Sunday Driver [schematic]
Postby zoetrop » 21 Mar 2017, 14:55
Thanks, I really like your schematic and thanks for your effort! could you please double-check R4, in the photo it looks like 4k7 instead of 47k (which would lead to a ~ 1.58 V bias)?
zoetrop
Have thanks: 25 times
Postby kusi » 21 Mar 2017, 16:47
thanks! r4 is 47k, voltage of 0,125V is measured. someone posted the schematic of Lehles paralell pedal here, the small bias-offset is similar.
viewtopic.php?f=1&t=27364&hilit=lehle
modman (05 Apr 2017, 21:43)
kusi
Postby apollomusicservice » 25 Mar 2017, 12:22
C2=100n
C6=10u
C12=1n
C13=120p
C14=330p
C15=15p
30-50mA current consumption
For this message the author apollomusicservice has received thanks: 5
Manfred (25 Mar 2017, 15:36), modman (05 Apr 2017, 21:43), plesur (01 Jun 2018, 11:41), twangcat (26 Mar 2017, 21:14), zoetrop (25 Mar 2017, 13:14)
apollomusicservice
Has thanked: 65 times
Have thanks: 760 times
Postby x-tn » 27 Mar 2017, 02:27
kusi wrote:...the power-supply is a bit strange, it's not the best idea to power a 9v linear regulator with 7,5V imho...
Your schematic says "all voltaged measured with 9Vdc power supply."
It looks like it requires AC power. With AC power you would have higher than 7,5V at the regulator input.
x-tn
Has thanked: 120 times
Have thanks: 15 times
Postby kusi » 27 Mar 2017, 07:07
of course 9vac would make more sense. but the manual clearly states 9V ac OR DC.
thanks apollomusicservice for the values!
kusi
Postby apollomusicservice » 27 Mar 2017, 21:59
kusi wrote:thanks apollomusicservice for the values!
No problem, I just checked values on my pedal.
apollomusicservice
Re: Lehle Sunday Driver [schematic]  [schematic]
Postby kusi » 28 Mar 2017, 06:15
updated schematic w. cap-values:
Cub (08 May 2017, 15:32), hasanova (30 Jul 2017, 20:13), lars-musik (04 May 2017, 08:17), Manfred (28 Mar 2017, 08:28), modman (05 Apr 2017, 21:44), toneman (30 Mar 2017, 21:54)
kusi
Postby apollomusicservice » 30 Mar 2017, 06:49
C15=15p
For this message the author apollomusicservice has received thanks: 2
hasanova (30 Jul 2017, 20:14), modman (05 Apr 2017, 21:44)
apollomusicservice
Postby kusi » 03 Apr 2017, 06:42
is c15 fitted in your version? because in mine it's not (but it doesent really matter if it's 15pF).
thanks for checking!
kusi
Postby apollomusicservice » 03 Apr 2017, 09:00
kusi wrote:is c15 fitted in your version? because in mine it's not (but it doesent really matter if it's 15pF).
Under the S/D switch.
apollomusicservice
Postby Cub » 08 May 2017, 15:31
Quite the power filtering! Almost seems overkill, but that's probably why I'm painting by numbers and the good people at Lehle are designing and building these things to put bread on the table.
Please forgive me if this sounds dumb, but would this filtering be helpful in a Big Muff circuit or an Overdrive / Clean boost to keep the noise down?
Cub
Has thanked: 67 times
Have thanks: 72 times
Postby FiveseveN » 08 May 2017, 16:01
Discrete designs like the more popular Big Muffs have poorer PSRR than something like this, so sure. But what exactly do you mean by "this filtering"? There's a rectifier, smoothing cap(s) and a regulator. Your PSU should already be regulated, but Lehle might not want to take that chance, and that's what the solution is about: flexibility and protection. You can feed it a wide range of voltages with either polarity or even AC and it will work just fine. Interestingly, the "standard" user case where you'd feed it with a proper 9V DC PSU is not the ideal condition, as the others have mentioned above.
For this message the author FiveseveN has received thanks:
Nocentelli (08 May 2017, 20:58)
FiveseveN
Has thanked: 125 times
Have thanks: 47 times
Postby Cub » 08 May 2017, 17:32
Thank you for your explanation, always eager to learn.
Cub
Users browsing this forum: chrisss1111, Gotflar and 20 guests
