Joyo - JF-02-B Ultimate Drive v2  [schematic]
alblupo
Been thanked: 15 times
Post by alblupo »
Hi everybody. This is the first time I start a new topic (and post a schematic) so I hope not to make too many mistakes :oops:
As I was not able to find it in the internet I traced the schematic of the infamous Joyo Ultimate Drive v2 (2010-11-24 version).
here it is:
Ultimate Drive schematics
For your convenience I prepared two pictures with values and component naming. I cannot warranty the naming is 100% compliant with the PCB silkscreen, as reading under the resistors was in many case impossible, but at least the naming is coherent with the schematics.
Ultimate Drive component names
Ultimate Drive component values
And now some comments about the changes between the first and the second version.
My educated guess is that this redesign was mainly intend to avoid possible issues on the intellectual property of the circuit design, by adding a buffer, rearranging the clipper, and changing one (insignificant) resistor value.
The first difference with respect to the 2009 version is the buffer formed by Q1, C1, C2, R1, R2 and D1. It is one of the most simple and common MOS-FET buffer. The input impedance is well above 1.5M in all the audible range. The Zener Diode (I was not able to read the exact model, so I put a plausible device) should be a 9.1V model intended to protect the FET from electrostatics. It is quite interesting to note that many comments on the internet refer to it as a wrong implementation of the millennium bypass but I respectfully disagree. They simply decided to add a (quite transparent and simple) buffer.
The second difference is that the MOS-FETs and the Ge Diode in the clipping stage have been rearranged. I have to point out that I put the Ge Diode as it should be and not as apparently is from factory. When reversed (as from factory) the clipping stage formed by the D2 and Q2 does not work so only one half-wave is clipped (by Q3). If you want it to sound as it was intended to be, check D2 and swap it.
The last (insignificant) difference is that R8 was changed from 10k (value that is used both in the OCD and in the 2009 of the ultimate drive) to 470K. It can be useful to note that due to the circuit design this resistor is not necessary and should have no effect on the sound. On the contrary the higher value could increase the thermal noise of the pedal, but probably in no audible way (I made no test). Anyhow, moving it back to 10K could be an idea...
What is clear is that this the pedal is no more true-bypass as the buffer is in front of the switch. Anyhow the "old" input stage after the 3TDP switch is unchanged. If someone want to turn the pedal back to true-bypass, it should be pretty strateforward to modify the circuit by removing C1 and C2 (the large capacitors placed in between the jacks) and putting a jumper in between the two holes closer to the PCB border. Obviously different implementations are possible, including providing the pedal with two alternative inputs one buffered and one unbuffered, or modify the pedal in such a way that the switching include the buffer too, making it again true-bypass. But that is another story and shall be told another time.
alblupo
Post by alblupo »
I have to apologize. I spotted some errors.
Namely:
R1 is connected to Vcc/2
I was misinterpreting R4 as R8 in the circuit and swapping in the component placement. As a consequence of this I was swapping the clipping stage orientation.
Here the corrected files
Ultimate Drive schematics, rev03
Ultimate Drive component names rev03
Ultimate Drive component values (unchanged)
howmuch
Has thanked: 21 times
Been thanked: 58 times
Post by howmuch »
Alberto, thanks for posting the complete schematic.
However, your clipping section is still not quite correct.
Check out my partial schematic of the clipping section here - Joyo - JF-02 Ultimate Drive "2010" MISTAKE
... and how to fix that diode.
Please check it again carefully. I think you'll find that the MOSFET gates are connected to the Sources, not Drains. That's true for the Joyo and the FT.
R.I.P. Burke Shelley, from one of my favourite (and much underrated) bands - Budgie
Their songs have been covered by Van Halen, Iron Maiden, Soundgarden, Metallica and more.
If you don't know how HEAVY this band was in the 70s, check Breadfan out.
alblupo
Post by alblupo »
howmuch wrote:Alberto, thanks for posting the complete schematic.
Yes, you are right, I was swapping the direction by mistake. BTW your thread about the "mistake" was one of the main inspiration for this work
Here it is:
Ultimate drive v2 schematics, 4th revision
And thank for checking!
Chugs
Has thanked: 63 times
Been thanked: 47 times
Post by Chugs »
Presumably, C4 is meant to be 0.068uf?
alblupo
Post by alblupo »
Chugs wrote:Presumably, C4 is meant to be 0.068uf?
Yes 68n as reported in the component values picture... I will fix the typo asap. Let's wait if you spot other errors 8)
howmuch
Post by howmuch »
Referring to your Rev04 schematic, here's some more errors I think
Your C9 should be 1uF.
Your R8 is actually 10k.
There is an extra 470k to GND after the buffer's 1uF cap.
alblupo
Post by alblupo »
howmuch wrote:Referring to your Rev04 schematic, here's some more errors I think
Yes you are right! I was naming R7 two of the 10K resistors! I will double check it again. About the 470k I have not fully understood were it should be connected, but for sure I missed something.
About C9, to me is a 10u electrolytic (it has the same size of C13 and it was reported 10u in the v1 too) but I will check it again.
I hope I can post a debugger version during the weekend.
Thanks a lot for the help
Alberto
alblupo
Post by alblupo »
Finally howmuch was right all the line! Thanks a lot for the useful help!
C9 and C13 have the very same size, but the first it 1uF 50V, the second 10uF 25V.
Here the updated versions of both the schematics and the component placement.
Ultimate drive v2 component values
Ultimate drive v2 component placement
If can comment again, a part form the "reverse diode" issue, the circuit is basically identical to the OCD v3 (as the "changes I spotted in my previous comment were just bad circuit tracing).
the 470kohm resistor (R4) is simply the buffer output resistor. In this sense, the buffer can act as a anti-pop (as someone reported) as it warranty that during the switching all the caps are connected to the ground.
I think now it is quite accurate, but if you seen any other changes or have any doubt, please contact me so that I can further fix the schematics.
Not it is time for modding :)
One not to people that want to perform the Freakish blues mods. Due to the added buffer all the caps after the buffer are "+2" with respect to the v1 (true bypass version), and all the resistors are "+3" (e.g. R1=>R4 etc..).
Have fun!
digitalzombie
Been thanked: 13 times
Post by digitalzombie »
I'm having a weird problem with mine. It sounds thin and the output is diminished compared to how it used to be. My band mate has one so I borrowed it to confirm it wasn't in my head. They're the same "2010" boards, and checking voltages on the IC and the BS170 at the input are nearly identical. Can anyone suggest where I should look for trouble spots?
digitalzombie
alblupo wrote:
Going over my circuit board with a continuity tester, it seems your orientations for Q2 and Q3 are reversed.
alblupo
Post by alblupo »
digitalzombie wrote:
Did you consider that I sketched the diode reversed with respect of how it is soldered (and silk screened) on the board? That diode have to be reversed to make it work properly.
digitalzombie
alblupo wrote: Did you consider that I sketched the diode reversed with respect of how it is soldered (and silk screened) on the board? That diode have to be reversed to make it work properly.
I'm wasn't considering the diode, but that's a moot point. I got my order swapped. Your diagram is correct.
n4m3less
Post by n4m3less »
if I wanted to remove the input buffer do you think there are any improvements in the sound? What changes without a buffer?
thanks
alblupo
Post by alblupo »
Currently I have modded the pedal in such a way that I have two inputs, a buffered one and an unbuffered one. I cannot say there is a lot of differece. That buffer is pretty transparent. But I am using only guitars with 250kohm pots... not sure if you have an higher impedance. I Think the main change is when you bypass the pedal... in one case it is true-bypass, in the other is not. If you have many pedals and long cables, the buffer should help, if you have not, or you have your own "trusted" buffer, it chould be better bypass it...
n4m3less
Post by n4m3less »
alblupo wrote:Currently I have modded the pedal in such a way that I have two inputs, a buffered one and an unbuffered one. I cannot say there is a lot of differece. That buffer is pretty transparent. But I am using only guitars with 250kohm pots... not sure if you have an higher impedance. I Think the main change is when you bypass the pedal... in one case it is true-bypass, in the other is not. If you have many pedals and long cables, the buffer should help, if you have not, or you have your own "trusted" buffer, it chould be better bypass it...
thanks for the reply! i made a bypass but i have a problem:
no output when pedal off (no sound)
work when pedal is on.
for bypass the buffer I removed the capacitors c1 and c2 and I shorted the 2 lower holes.
bypass mod.JPG (8.35 KiB) Viewed 5543 times
What did I do wrong? How can I solve?
thanks
alblupo
Post by alblupo »
thanks
I was just having a fast check and should work. I think you should disconnect R3 too, otherwise you have a 470k resistor in parallel to you signal always,
Another way to bypass the buffer is connect the "input" of C1 directly to the "from the buffer" wire of the bypass switch.
n4m3less
Post by n4m3less »
thanks
thank you! I understood my mistake ... I had followed your scheme of the first post and I had not seen the 470k resistor on the circuit.
alblupo
Post by alblupo »
thanks
Yes, unfortunately I made a number of interaction prior tracing properly the circuit. Let me know if it works after the further mod.
