Hello Fuzz Lovers,
Did some Work on the Red Witch Ruby Fuzz, which was initialised by pk1802 on this Thread:
https://www.freestompboxes.org/viewtopic ... zz#p272505
I found this idea very fine with the Akku driven "to go fuzz" and finally bought one. Because it had a terrible sound (some scratchy crossoverdistortion/Digital distortion like),
I decided to open it up for modding it- Hard work- it took hours with magnifier-but at least...
Volume pot is right, don´t know why they wired it that way (was my first mod- twisting th legs of poti...)
The two Caps with question mark have no value print but i took in the two values of the FuzzGod input because it´s the simplified FG input section.
The trannys print is 1S its for the 2n2369A smd equivalent (see schemo)
the low output is selfexplaining: they just put in the standard fuzz face 470R above output on Collector 2, but with 10 times higher Rc and Re
what means the output normally is attenuated instead (for example) 8200:470 is now about 82000:470
What i like is dimming the fuzz with the variable bias resistor (R14) will try this in other Fuzzes
Second mod was puttting in a bigger emitter Cap of 22µF instead of the 1µF(the reason of the terrible sound)
The output cap was guess too but after killing it i put in 10nF sounded the same as before
Can only do some PDF with Target 3001, so its as Attachment.
Have Fun
