DOD - FX51 Juice Box  [schematic]
alteredsounds
Post by alteredsounds »
Great sounding box from the old DOD FX range, if anyone's interested I'll do values and the trace side
puppiesonacid
Been thanked: 12 times
Post by puppiesonacid »
yeah im interested. post away.
PurplePeopleEater
Been thanked: 5 times
Post by PurplePeopleEater »
Definitely - the Juice Box is one of my favorites. Great sounding OD. IIRC, it's basically the Bad Monkey with more EQ.
alteredsounds
cool, i'll get to work on it, was looking at maybe reversing the Zoom Ultrafuzz too if there's interest, cant see if its been done
Entrant_21
Post by Entrant_21 »
Hey definately trace it, sounds like a great pedal!
Cups
Post by Cups »
I own one. I really like it. Been looking for a schematic since forever.
blanik
Post by blanik »
there's two 4558 and one 4007UBE, is the 4007 just used for the switching or is used for clipping??
Has thanked: 232 times
Been thanked: 888 times
Antiparallel diodes bottom left. Assume clipping.
4007 in a DOD? assume bypass switching.
Love it when manufacturers stick to a working topology.
and yes please, give us all. Tracing shouldn't be that difficult. :mrgreen:
borislavgajic
Has thanked: 131 times
Been thanked: 281 times
Post by borislavgajic »
why not :mrgreen: ?
himister
Has thanked: 21 times
Been thanked: 30 times
Post by himister »
+1 Count me in Boris. :applause:
nexion777
Has thanked: 65 times
Post by nexion777 »
Here the schematic (I hope is right).
https://www.diystompboxes.com/smfforum/ ... ic=80440.0
But... Can we have a gutshot for the track side? :blackeye
DOD Juice Box schematic
Bernardduur
Has thanked: 94 times
Been thanked: 737 times
Post by Bernardduur »
I've bought a broken one for dirt cheap........
And I must say the problems with this unit is as many others have descrived in the online fora. It is bright, the controls have sometimes little to change and the overal sound (with a clean amp) is pretty clangy / overly bright. When combined with an already OD'ing amp it works pretty well...........
So I wanted to see what I could change.
The pedal's brightness is part due to the design and part due to the chosen values of the potmeters. All potmeters in this unit are 100k lin and that doesn't work that well for some paramters. The gain (called 'juice') doens't do anything on the first 50%, then suddenly all nice gain structures can be made. Same with the treble (called 'Tang') that does not function between 20 -100%; only the first 20% really change the treble from down and bassy to high and shrill. Time for a change!
I added a 100k resistor parallel to the gain potmeter. Now I can dial in a lot of gain sounds much better.
I added a 1u cap to the 0.22u cap on the opamps feedback loop to get some more lows in the higher gained settings. Works pretty well!!
I added a 47k and a 10k to the treble potmeter (between the lugs); with these changes it now functions from 0 - 75% perfectly!
This made the unit already great, but I wanted more! There is one gyrator for the lows (approx 106.3Hz / Q=1.47) that is tied to a potmeter so the lows can be dialed in. Another gyrator (approx 876.6Hz / Q=1.21) is set to max. I added another 100k lin potmeter to the unit to dial in the mids. This function really makes the pedal shine! In the lower mids setting it becomes a transparant drive pedal, on the higher mids setting it really cuts through the mix (tubescreamer like). Nice!!
One last thing I noticed is the 'clean interference loop' (Q5 - R21) that I put on a switch. I was expecting it to behave like a clean blend and making the pedal sounds fuller and more broad. But I was surprised to find out that switching this circuit in made the sound only worse. It lowers the output and makes the mids stand out more (a more focussed or edgy sound). Switching this circuit off really opened up the pedal and make it more broad sounding with nice lows and highs.
I dunno why this behaves like this. I can only guess a phase interference to make these sounds. I'm glad that I made it switchable!!
