Ampeg - Sub Blaster  [schematic]
Re: Ampeg - Sub Blaster
Postby PoorCadaver » 20 Aug 2013, 14:47
chicago_mike wrote:The official schematic was published earlier. :)
It was from Ampeg themselves. In the DIY layout there is a missing connection from the CD4013.
I would trace your signal before the 4103..the gain structure feeding it, just to see of those opamps are working correctly. :)
For Octave pedals...its a simple circuit.
Is this the final schematic?
download/file.php?id=7634
Where can I find the schematic from Ampeg?
PoorCadaver
Postby chicago_mike » 20 Aug 2013, 18:45
I got it oon my drive somewhere. I'll repost.
Also I have the schematic for the Aguilar Octamizer. BUT..aguilar blocks out some things. All their pedals have the real important part blocked out, because its under a gooped section that they just replace if busted.
I'll dig that up too.
Skyline FX 2013
chicago_mike
Has thanked: 23 times
Have thanks: 283 times
Postby PoorCadaver » 21 Aug 2013, 07:43
Thanks pal! You'll make my day. :)
:applause:
PoorCadaver
Postby chicago_mike » 21 Aug 2013, 14:14
Here is the pdf I got from ampeg.
And the Aguilar Octamizer.
The part that is blocked out of the aguilar should not be hard to figure out.
Skyline FX 2013
For this message the author chicago_mike has received thanks:
x-tn (24 Aug 2013, 13:56)
chicago_mike
Postby PoorCadaver » 21 Aug 2013, 23:12
Great, thanks!
PoorCadaver
Postby Trippy Demon » 30 Sep 2013, 10:23
Hi all, I'm bumping this topic because I've made a pcb to fit a 1590B enclosure
pcb size: 75x55mm
Furthermore the original ampeg schematic has some slight value improvements that tune and track the octave better
(schematic can be clicked to open in photobucket where it can be enlarged)
For this message the author Trippy Demon has received thanks: 6
aishabag23 (16 Dec 2017, 06:52), chicago_mike (30 Sep 2013, 13:19), lohstah (03 Oct 2013, 08:45), lolbou (03 Oct 2013, 20:28), modman (01 Sep 2014, 22:47), rcustoms (30 Sep 2013, 15:20)
Trippy Demon
Have thanks: 8 times
Postby Trippy Demon » 30 Sep 2013, 13:18
Hmmm, this seems the only way to my breadboard test video... weird...
http://youtu.be/JeqHHm2sKUw
Trippy Demon
Postby chicago_mike » 03 Oct 2013, 18:45
Cool!!!
Skyline FX 2013
chicago_mike
Postby Trippy Demon » 08 Oct 2013, 07:38
There's a tiny mistake in the pcb, forgot one little path between the 10K res. and the 0,1µF cap. on the green VREF line on the right middle
here's the right pcb layout:
And my own style schematic including all the jack and pot connections
Nocentelli (08 Oct 2013, 19:42)
Trippy Demon
Postby Jarno » 08 Oct 2013, 08:47
Those drawings are nice, I really like that style. Adobe Illustrator?
Jarno
Postby Trippy Demon » 09 Oct 2013, 11:09
Yes, Illustrator, never seem to need anything else...
Trippy Demon
Postby Trippy Demon » 12 Oct 2013, 10:43
Was also a mistake in the schematic, but this is the definitive one
Trippy Demon
Postby PoorCadaver » 13 Oct 2013, 13:53
I see that you have placed C1 (1uF) so that + goes to vref but in the schematic - goes to vref. Is your PCB version verified?
For this message the author PoorCadaver has received thanks:
Trippy Demon (14 Oct 2013, 12:07)
PoorCadaver
Postby Trippy Demon » 14 Oct 2013, 12:07
PoorCadaver wrote:I see that you have placed C1 (1uF) so that + goes to vref but in the schematic - goes to vref. Is your PCB version verified?
Schematic is right, C1 has to be turned around, thanks for noticing that, I'm still building this and it's not verified jet, so proceed with caution
The last Schematic is verified as far as that I built it on breadboard and that worked
Trippy Demon
Postby Trippy Demon » 14 Oct 2013, 12:28
Rotated C1-1µF so that minus side goes towards VREF, I will make a Schematic and Layout with component numbers when I verified all for myself
Trippy Demon
Postby Trippy Demon » 15 Oct 2013, 11:34
Alright, finished building and debugging, the 1N4002 also needs to be turned around on the pcb, so here's the verified pcb layout
Last schematic is also verified, leaves me to show you the finished result
And some gutshots, was still unwired at the time:
On to further solder adventures! :mrgreen:
modman (01 Sep 2014, 22:51)
Trippy Demon
Postby PoorCadaver » 15 Oct 2013, 17:34
Great work! Looking forward to build this.
PoorCadaver
Re: Ampeg - Sub Blaster  [schematic]
Postby mictester » 15 Oct 2013, 18:09
Trippy Demon wrote:Was also a mistake in the schematic, but this is the definitive one
Nope - it's still wrong. I've fixed the first mistake I've found:
For this message the author mictester has received thanks:
[Gringo] (26 Mar 2019, 14:29)
mictester
Has thanked: 33 times
Have thanks: 802 times
Postby chicago_mike » 15 Oct 2013, 18:47
Plenty of room inside to do Aguilar mods to it. :D
Skyline FX 2013
chicago_mike
Postby Trippy Demon » 16 Oct 2013, 07:27
chicago_mike wrote:Plenty of room inside to do Aguilar mods to it. :D
Weeeeeell, if enough room is left and right of the 3pdt then yes, because the rest is pretty tightly packed with the wires in the 1590B (110x60x30)
But you can always go for a 125B (120x65x35) which is slightly roomier inside, and because I like my in- and outputs on the back that's the box I'll go for in the future
Trippy Demon
Users browsing this forum: karua, MBens11 and 16 guests
