Ampeg - Sub Blaster  [schematic]
Re: Ampeg - Sub Blaster
Postby modman » 01 Sep 2014, 23:06
What an incredible thread to look at: spanning almost 4 years, through 3 or 4 personal trace attempts, in order to be sidetracked by a factory schematic with mistakes, to still come home.
:applause:
Has thanked: 3113 times
Have thanks: 564 times
Postby chicago_mike » 05 Sep 2014, 02:42
This thread is almost 4 years old???? Crap, what the hell have I done with my life!!!!! :slap:
Skyline FX 2013
chicago_mike
Has thanked: 23 times
Have thanks: 283 times
Postby amapolasola » 26 Jan 2015, 23:25
Hi there,
i changed all caps in my original sub blaster ; when originals caps were soldered i saw for C10 ...KAN 423
C16 ...KFE 449
C13 ...KAN 503
C5 ....KBL 317
C8 .......KFE 449
...but it meant nothing ! So when i desoldered caps i saw for c10 ...332 ...it's 3.3nf
c16 and c8....104...it's 100nf
c13 ...473.....it's 47nf
c5...224 ...it's 220nf
c6...153...it's 15nf
so, in the case where caps are coded...(yes that exist) you have to take capacimeter !
i wanted to change opamp tl062 too. I tried and tested opa2134, LM4562, OP275, NE5532...but in this circuit nothing o fthese opamp was better than tl062 ! You have of course a signal, it's very special to define this signal. I built a divided octave too ; and opa2134 work very good with this unit !
I dont have mods for sub blaster, but someone have any mods ...yyuuuuuuuuuuuuu "welcome"
greetings
amapolasola
Postby chicago_mike » 27 Jan 2015, 03:35
You can put a variable filter in the tone control section, like EBS Octabass or the Aguilar Octamizer. :)
Skyline FX 2013
chicago_mike
Postby roseblood11 » 31 Jan 2017, 22:57
Is there a complete schematic (and maybe a layout) for the Aguilar Octamizer?
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Postby chicago_mike » 28 May 2017, 20:48
Aguilar epoxies the circuits. And the service manuals don't show the epoxied parts.
Skyline FX 2013
chicago_mike
Postby rocket8810 » 02 Aug 2017, 17:02
i've got the aguilar octamizer and would be happy to help figure out what's under the epoxy. any idea how to get it off?
rocket8810
Have thanks: 22 times
Postby bmxguitarsbmx » 02 Aug 2017, 21:31
Looks like a boss oc-2 with only one octave. The level dependant comparator circuit is the interesting part imo.
bmxguitarsbmx
Has thanked: 267 times
Have thanks: 82 times
Postby rocket8810 » 29 Sep 2017, 01:55
i worked through the parts of the aguilar octamizer PCB that's traceable, ie not under the black epoxy, and it's definitely based on the sublaster.
For this message the author rocket8810 has received thanks:
lohstah (05 Oct 2017, 19:34)
rocket8810
Postby analoguist21 » 13 Jun 2018, 17:45
Trippy Demon wrote:Alright, finished building and debugging, the 1N4002 also needs to be turned around on the pcb, so here's the verified pcb layout
[ Image ]
Trippy Demon wrote:Was also a mistake in the schematic, but this is the definitive one
[ Image ]
Hello everybody,
first of all a big THANKS to all the guys who work on that, the topic is wonderful !
I'm about to build it, is there any little mistake on the last PCB and schematic ? it seems all right !
Can't find the BOM, i will do and post it !
Last question:
I wonder if i can add FX loop on the Dry signal, just before the direct pot, with a ringer, like the mutron octave divider :hmmm: ?
am I wrong ?
Regards !
analoguist21
Postby analoguist21 » 22 Jul 2018, 19:11
http://docdro.id/oLJBmb7
Here's a little document with the B.O.M and labels.
I'm ordering that now, I will post some photos of my work !
analoguist21
Previous
Users browsing this forum: BAMF, guidirestraits, qersty, Vitallka and 7 guests
