Danelectro - CO-1 - Cool Cat Drive [schematic]
- Pedalpusher
I've been tracing the circuit up to the input of the second opamp and looks to be wired just like the OCD. That is the clipping diodes are wired the same as The OCD's. They are not transistors wired as diodes though. More to come.
- Pedalpusher
If the MarkM schematic is accurate then the CC Drive is based on the OCD and laid out the same way. FB loops, diode clipping, tone and volume, it's all the same. I haven't figured out all the values yet though.
- Pedalpusher
There's some in the Transparent OD thread.
Not trying to complain too much, but can mods help with this. Really hard to follow threads when we have multiple things going on.Pedalpusher wrote:There's some in the Transparent OD thread.
- Pedalpusher
That's why I started a new thread. I hope to get some high res pics before the weekend.
The OCD is a VLOD with mosfet clippers. So if a "Drive" is an OCD without the mosfets its just a VLOD.
Innit ?
Maybe all the horseshit being flung around here is confusing me.
Innit ?
- Pedalpusher
Analogguru said in another thread..."Save your time, when you want to do it like fuller did.....
That´s not mos-fet-clipping, that´s normal diode clipping even with mosfets
The inside-protection diodes are not mosfet-diodes, they are normal and will conduct long before the mosfets will conduct."
So fucking what ? AGs opinion is irrelevant to the thread you started. YOU have made a serious allegation of commercial copyright infringement ...Pedalpusher wrote:Analogguru said in another thread..."Save your time, when you want to do it like fuller did.....
Given that the OCD is a tweaked VLOD with mosfets as clippers (and that is a FACT, Fuller admitted as much), if you build it without mosfets its just a tweaked VLOD. Of course that doesnt help anyone jump on the bandwagon to nail the evil builders for cloning. And BTW Stratotastros OCD schematic is correct for the OCD Rev 4 that I had.If the MarkM schematic is accurate then the CC Drive is based on the OCD and laid out the same way. FB loops, diode clipping, tone and volume, it's all the same. I haven't figured out all the values yet though.
- TubeDude22
Good detective work, Snyder80.
according to the values of the output "buffer" with a 470k from V+ to the transistor and 47k from transistor to ground, maybe its more some sort of booster like a lpb -1/-2.
Also the pedal can get sooooo loud, your amp will go to "21". thats +10 more than "just 11"...
- Pedalpusher
I said it was OCD-ish since I hadn't completely dissected it. Like I'm the first one that's made a "serious allegation of commercial copyright infringement." What I said was true. That it's at least similar to the OCD. That's what OCD-ish means in case You're having trouble figuring that out.Torchy wrote:
- DougH
Let's see... You just described about 99% of all the op amp based overdrives out there. Don't see where this is particularly "OCD-ish" or "Anything-in-particular-ish" based on this info.Pedalpusher wrote: FB loops, diode clipping, tone and volume, it's all the same. I haven't figured out all the values yet though.
- Pedalpusher
Well go ahead and delete the fucking thread if You're having so much trouble with it. I wasn't saying it had all those. I said they were wired the same way. A TS doesn't have the clipping diodes wired the same way as the OCD. Damn! You guys have been doing this shit since this forum started and I mention the OCD and You shit Your pants. Delete the thread. Better yet delete the forum.
- DougH
Here's a suggestion: When you start a thread about what you think something is- back it up with photos. If you don't have the photos yet, wait until you do until you start a thread. Don't post speculation as it just spreads misinformation.
- IvIark
I don't think it was spreading misinformation, I think some people should maybe chill out a bit. Pedalpusher was simply giving his initial thoughts and by the looks of the drawing by snyder80 it would appear that his hunch was fairly accurate.
- Uma Floresta
Way too much drama. TGP is that way. ->
