Maxon - OOD-9 ( Organic Overdrive )
briggs
Has thanked: 27 times
Been thanked: 128 times
Post by briggs »
Anyone got information on these:
http://www.pedalspluseffectswarehouse.c ... s-ood9.htm
All I can find is that it is an updated version of the OD880....
Infact I'm interested in the whole of the Maxon range so if anyone has any other maxon schematics please can you stick a link down so I can check them out!
Cheers!
I am Klon.
Been thanked: 124 times
The name says everything: "Organ Overdrive"
- You are on the best way to it by drinking to much beer you will "overdrive" your liver
And while listening to the sound samples I got problems in my stomach:
Only one "Sauce(rful) Of Secrets"
JHS
Been thanked: 5 times
Post by JHS »
Std. Maxon IC-I/O-buffer and some classic OD-circuit in the middle.
25mA power consumption, that's very high for a classic circuit, maybe there are LED-clippers inside.
JHS
JHS
Post by JHS »
I forgot to say that the OD-circuit is the old OD-880 and that it has +/-4,5V supply for the IC yielding in a bit more voltage swing.
IMHO there'a a charge pump inside doing the voltage splitting.
Good MC 741 are hard to get, hence that's the reason while they switched to 4558Ds.
JHS
briggs
Post by briggs »
Cheers..
I am Klon.
Has thanked: 183 times
Been thanked: 468 times
From the description: "True Bypass Switching with 4PDT mechanical switch. No tone changes when switching bypass/effect."
What? Where is that? Is it a microswitch hidden under the actuator like found on the current Behringer "Vintage" series pedals? Why 4 poles? I don't get it. When did they stop using the electronic switching?
gnognofasciani
Been thanked: 11 times
Post by gnognofasciani »
soulsonic wrote:From the description: "True Bypass Switching with 4PDT mechanical switch. No tone changes when switching bypass/effect."
Maybe just to blow customers' minds :lol:
Okay, I looked it up on the Maxon website. Apparently, they actually do use a 4PDT microswitch under the actuator. They claim that they had to start using the 4 pole switch for those effects that have dual outputs and then they just started putting it in all of them to please those people who demand 3PDT bypass switching. Hmmm.... interesting.
vanessa
Post by vanessa »
It blew my mind. I'm still in rehab recovering from it...
[smilie=a_dreaming.gif]
Maxon found taste on the booteek-spirit:
$ 195,-- :shock: for a new "invention" to the 9-series:
https://cgi.ebay.com/Maxon-OOD-9-Organi ... dZViewItem
Somebody knows what the new myth:
post-integration overdrive circuit
should be ? .....discrete would be "pre-integration"....maybe this has to do with "masters" and the integration of "slaves" ? :roll:
platinum321
Post by platinum321 »
Somehow that pedal looks familiar. Dejavu or something. Can't seem to figure it out.
jrc4558
Post by jrc4558 »
Dear all,
Has anyone ever seen the guts of the MAXON OOD-9? Its function puzzles me, but not so much as to shell out $260 for a direct purchase.
Here's what's in the description I found online (at ebay, not Maxon):
"Overdrive sound from post-integration circuit smoothly changes according to input level, offering highly dynamic response to picking technique. Creates mild and warm overdrive like that of a tube amplifier. Industry-standard op-amp, JRC NJM4558D offers low-noise overdrive sound. Employs a passive type overdrive circuit which differs from OD808/OD9. OOD9 is most effective with tube amp, using like a booster."
What in the world is passive type overdrive? What's the battery for, LED? :)
Maxon website quotes OD880 circuit as main inspiration.
I'm thinking...
MoreCowbell
Been thanked: 15 times
Post by MoreCowbell »
jrc4558
Post by jrc4558 »
It is indeed, but no schematic. :) I thought of a charge pump too, that would explain higher current draw.
MoreCowbell
jrc4558 wrote:It is indeed, but no schematic. :) I thought of a charge pump too, that would explain higher current draw.
You didnt ask for a schematic...you asked if anyone had seen the guts, what a passive od was, and what was the battery for . :D :D :D :D :D
seriously though... i'm sure AG will merge the threads together, as this really should have been added to one of the existing threads.
Professor SourTone
Been thanked: 58 times
Post by Professor SourTone »
The clips sound fizzy and muffled to me. Also most of those Maxon/Ibanez pedals are best used as a boost with the gain down (except for the Ibby OD9/OD850 which are fuzzes) so no change there.
Greg
Completed builds: LOTS..
Has thanked: 65 times
Been thanked: 164 times
Post by Greg »
Professor SourTone wrote:The clips sound fizzy and muffled to me. Also most of those Maxon/Ibanez pedals are best used as a boost with the gain down (except for the Ibby OD9/OD850 which are fuzzes) so no change there.
You're right... those clips are horrible.
patafix
Post by patafix »
Some kind of boss od-1 cousin ???
Patafix... so sticky
Has thanked: 232 times
Been thanked: 888 times
necro-bump?
