RC-2 Mod ?
I don't mind (at least, not too much) the fact that the RC-2 has to be powered up for the amp to function, but would like some sort of switch on the pedal to be able to power it up with a foot tap, instead of plugging/unplugging the adapter all the time.
Am I missing something here? Add a switch?
Thanks for the help.
Rich
Rich
- Hides-His-Eyes
I'm quite confused. Can you not switch it at the wall?
- mysticwhiskey
Seems like you've made yourself a problem that's now in search of a solution. Why not just get a regular switched powerboard, plug your amp + adapter(s) into that, then that goes into the surge protector. You don't need another surge protector since the one plugged in at the wall's got you covered.
