I recently bought a TS9 as a substitute for my SD-1, and afterwards i thought i'd give the SD-1 a spin on the workbench, to see if i can get it to behave a bit more like i think it should.
I'm the kind of guy who learns best by writing stuff down while studying on the subject, so i thought that as i progress, i might as well write an entry level article about the various building blocks of the circuit (input- and output buffers, drive circuit and tone control circuit mostly), and list some of the crucial mod-points with audio examples along the side, so that n00b's like myself - at this point at least - can easily understand where to mod their SD-1 to get the sound they're after.
I understand that the SD-1 and the TS9 are almost identical circuit-wise, so a little TS9 reading as well as technical explanations about the structure of the various blocks, won't scare me off. I find myself capable of handling a fair level of abstraction
So far i've written an introduction to my SD-1 modification journey. I really hope you guys can point me towards some interesting reading about the various circuit "blocks".
Peace out! /grrrungeAbstract:
My musical preferences drives me towards the use of modern hi-gain guitar amplifiers such as ENGL, Mesa/Boogie, Soldano etc. Even though these amps tend to deliver more than enough overdrive on their own, i really like the extra oomph they deliver, when i slam the front of the amp with a slightly overdriven, boosted guitar signal.
To do so, i have been using a BOSS SD-1 "Super Overdrive" for quite some time. Even though i like it a lot, i find it a bit insufficient for my use in the following points:
⁃ The high mids gets a bit too lo-fi for my taste.
⁃ The punchy lows that my amps provide on their own seems to disappear when i engage the pedal
⁃ As i only use the lower gain settings, i don't need blistering amounts of overdrive from the pedal, instead i would like to have more control of the lower gain area (from 6-11 0'clock on the stock SD-1)
⁃ On "higher" low gain settings, the sound tends to get a bit compressed. I prefer an open "breathing" sound from the overdrive section, as i can always use a compressor later in the signal chain.
⁃ The higher drive settings seem a bit too harsh for my taste
Project Description:
To suit my needs from the pedal better, i would like to replace existing components on the SD-1's PCB to achieve the following when the pedal is engaged:
⁃ Accentuate high mids
⁃ Retain the guitars natural low end response
⁃ Reduce overdrive, thus increasing control over the lower gain settings
⁃ Obtain smoother, less compressed overdrive
First Hand Experiments:
Before i started this project, i installed a DIP-8 socket in place of the JRC4558DD chip that came in the stock unit. I toyed around with various op-amps, and found that i liked the sound of the MC1558N better than the other chips i tried, including the stock JRC4558DD, JRC1458D, JRC5532D, CA3240E and a TL082CN. I have yet to try the OPA2134 stuff. I suppose that's gonna come around sometime too.
