SD-1 Background Noise
ct88
Been thanked: 9 times
Post by ct88 »
hey guys, i TrueBypassed a modded SD-1 to avoid bad buffers on bypass, but a problem came out: when i turn it on i obtain a lot of popping noise.
Any Suggest on how to solve that?
Thanks in advance :)
ct
DrNomis
Has thanked: 98 times
Been thanked: 279 times
Post by DrNomis »
ct88 wrote:hey guys, i TrueBypassed a modded SD-1 to avoid bad buffers on bypass, but a problem came out: when i turn it on i obtain a lot of popping noise.
ct
Try putting a "pull-down" resistor on the input on the circuit board, a good resistor value is anything from 1M to 4M7, hope that helps..... :D
ct88
Post by ct88 »
already done but nothing new on pop noise :\
mictester
Has thanked: 32 times
Been thanked: 845 times
Post by mictester »
ct
Put it back to how it was! The buffers neither add nor take away from the sound of the effect. They are actually beneficial in the bypass mode because they provide high input impedance and low output impedance, so they will drive long cables or other effects without losses.
I really can't understand the obsession people have with "true bypass" and "no buffers"....
ct88
Post by ct88 »
i have better Buffers @the start and @the end of the chain :D i hate Boss buffers because the "eat" a bit of top-end :) thats why i truebypassed :)
quaternotetriplet
Has thanked: 10 times
Post by quaternotetriplet »
add pulldown resistor on the output side... 10k will do.
