Behringer - Vintage Distortion VD1 improvements
- pinkjimiphoton
- my favorite amplifier: my own, a redesigned princeton
- Completed builds: so fucking many goddamn pedals it would make your ass hurt just looking at 'em all!!!!!
there's videos that totally suck of about 90 of 'em here:
http://youtube.com/666pinkster
gimme a like: http://facebook.com/pinkjimiphotonrocks - Location: new world order land (formerly la-la land)
- Has thanked: 358 times
- Been thanked: 480 times
- Contact:
hi guys, decided to break my vintage distortion today.
and came up with an easy mod that seems to give it more clarity, headroom, and much better (imho) fuzz.
all ya need to do is open it up, and look at the main circuit board...there's 4 little diodes, and all the bands are facing the same way, towards the mounting screws.
take your iron, and remove the first two diodes...heat the side opposite the band first, then the side with the band, and they'll pop right off.
now the fun part...
take a ge 1n34a, and carefully solder it in place of the first diode (they're labeled d2,3,4,& 5) with the band facing the same way as the two that are left. that's it.
to me, it made a huge diff in the tone...
for extra points, add a switch with another diode from the unbanded side of d3 to the banded side of d4...maybe add a volume pot...you may be able to get it to do some weird shit like drop the tone an octave of fuzzy goodness.
anyways, hope ya diggit if ya try it. have fun!!
peace
jimi
now the fun part...
peace
jimi
Slava Ukraini!
Slava Ukraini!
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Has thanked: 70 times
- Been thanked: 66 times
- Contact:
Gotta try that.
Right now, on mine there is a switch to remove those diodes in the first clipping stage. This provides a huge increase in bass and volume, and more of a fuzz feel than a distortion. Great with bass too !
I could easily change the switch for a on-on-on and try other clipping arrangements.
Damn, one more item on the to-do list.
- pinkjimiphoton
- Contact:
it's a fun circuit to play with for sure, subtle changes can lead to some big changes in the sound!!
Slava Ukraini!
Slava Ukraini!
- Andy2No
I'd love to see some gut shots of one of these. I did a quick search, but I couldn't find any.
Is the standard Big Muff schematic applicable to these?
Are the components all "man sized" ones, or have they used SMD?
http://www.harmonycentral.com/forum/for ... 74-/page24Andy2No wrote:I'd love to see some gut shots of one of these. I did a quick search, but I couldn't find any.
http://www.harmonycentral.com/forum/for ... 9/1817565-
collective speculation (for all that's worth) across most forums where i've read things about it seem to suggest it's a muff or a very slightly tweaked variant of.
- Andy2No
Excellent. Thanks, tabbycat.... The button has gone missing again, or I'd press it.
I love how much empty space there is around those tiny circuit boards I wouldn't fancy trying to swap out those SMD resistors and capacitors though, to try different values.
I actually went to a shop to buy one, earlier. Their website said they had them in stock, for £31.99 GBP (about $50-$55, I guess). It turned out they didn't, but if I see another one for sale I may still get it.
Very much off topic; I bought a Behringer BLE100 Bass Limiter / Enhancer while I was there though. The first two knobs are good, though the Enhance knob adds a fizzy sort of LFO noise in the background, at higher levels. The other two knobs are too subtle to be sure what they're for There are some normal sized small can electrolytic caps though, so I may try messing with those, at some point. On the whole, not a total disaster.
I also picked up a faulty BOSS CS-3 compressor in a second hand shop, on the way there. I talked the guy down to £10 ($15 or so). As soon as I took the back off when I got home, it started working. It seemed to be shorting out on the back plate, so I put some cardboard under the PCB. Result!
The CS-3 has very similar controls to the BLE100 - four knobs, in the same order, and also gets noisy with the tone knob (=Enhance) turned up. The Attack and Sustain knobs actually do something useful though.
- JiM
Proco Rat
Hot Harmonics
Crackle Not OK
- Contact:
I've traced it to be a Big Muff indeed, but a mix of different revisions.tabbycat wrote:collective speculation (for all that's worth) across most forums where i've read things about it seem to suggest it's a muff or a very slightly tweaked variant of.
