Hello pedal sages, im looking at tweaking the sustain range on my already modded CS3.
http://www.dirk-hendrik.com/images/cs3.gif
schematic above
am i right in thinking the 4k7 and 22k in the bottom left sets the min and max ranges for the sustain pot?
oh and which is which, is the 22k going to be the minimum if so? thanks muchly
BOSS Cs-3 sustain pot taper
- mictester
They do limit the range available to the pot, to prevent either saturating or completely cutting off the FET that's fed from the associated op-amp. There's no point in changing them - you'll just change the pot's range to working over a small part of it's rotation!darkstar wrote:Hello pedal sages, im looking at tweaking the sustain range on my already modded CS3.
schematic above
am I right in thinking the 4k7 and 22k in the bottom left sets the min and max ranges for the sustain pot?
