Danelectro - Surf & Turf: Keeley Compressor Mod
Hi All.
I recently discovered that the schematic for the Danelectro Surf & Turf Compressor can be modified to the Keeley Compressor(either 2 or 4 knob).
If you look at the schematics you can see that they are similar, in that the major differences lie in the clipping, trim, and attack. The sustain which is termed 'sensitivity' in the Danelectro just needs to be rewired. A couple other components need to be removed and voila! I will add the mod schematic in a day or two.
K. I got bored tonight and decided to draw up the mod. Here it is.
If anyone is into vintage tube compression leave me a post. I am currently working on a project reverse engineering transistor compressors to tube compressors.
- IvIark
Nice work!
