Lets See those Danelectro Re-house glamour shots
lexluthier72
Post by lexluthier72 »
Hey Folks,
Just joined the forum, and I am interested in re-housing my Danelectro Rocky Road. I searched for topics on the rocky road in particular, and got very little. Id like to see some finished projects, so I can see some sort of layout, and also what parts were completely replaced. Does not have to be the Rocky Road...lets see em!
-Erin
lexluthier72
What....Nobody has ANY dano's they have re-housed? Cmon.... =(
guitarjoem
Post by guitarjoem »
Click the thumbnail for a slideshow...
lexluthier72
Nice! Is the case etched....?
Dan N
Has thanked: 58 times
Been thanked: 21 times
Post by Dan N »
Sorry, no guts. This is a rehoused French Toast.
Dick joke has expired.
Wonderdog
Post by Wonderdog »
Here is the Rocky Road re-housed.
I left the switching/buffered bypass in place, but put in metal momentary footswitches.
I did the unity gain mod and the 8mm led under the knobs is orange, and flashes in time with the speed.
However, hooking up the speed led affects the sound slightly, so the toggle switch in the upper right cuts out the flashing led and restores the full warble.
The 5mm led is on/off. The decal I created on PC paint and glows in the dark.
The red clipping led's on the board are socketed. I replaced them with jfet transistors shorted to form diodes, and now the thing is an awesome fuzz/overdrive box as well as a leslie simulator.
Case shot
Case shot
Gut shot
Gut shot
Wonderdog
Post by Wonderdog »
Here is my Chicken Salad re-house. First pedal I ever made.
True bypass, speed led, trim pot external mount.
The speed led is the large 8mm purple led in the center. Always on.
The small red led is on/off.
The graphics are printed on glow in the dark sticky paper covered with a tough clear film.
Sounds awesome. Looks cool too.
lexluthier72
Wonderdog....SWEET! Thanks much. Everyone, Id love to see more....seems there is not alot of info out there on re-housing....But at least now, I have an idea of layout, and what new parts are involved. Thanks again
-Erin
guitarjoem
lexluthier72 wrote:Nice! Is the case etched....?
Yes.
Wonderdog
Post by Wonderdog »
Here is my Chicken Salad re-house showing the glow-in-the-dark feature. :thumbsup
Dr Tony Balls
Been thanked: 172 times
Post by Dr Tony Balls »
Dan N is that a fuzzy box, like the Foxx Tone Machine??? If so where did you get it or how did you make it??
Dan N
Post by Dan N »
Dr Tony Balls wrote:Dan N is that a fuzzy box, like the Foxx Tone Machine??? If so where did you get it or how did you make it??
It's flocking powder I got off ebay. You're supposed to get your box wet with paint (the same color as the flock you want to use) then sprinkle the stuff on top. I had better luck spreading the stuff on a flat surface, painting the box, then shoving the wet box down into it. I usually have to do that twice to get a thick coat. It looks swell, but does not age well.
A well worn beebaa clone:
http://users.rio.com/senorris/junk/IMG_0002.jpg
lexluthier72
Hey Folks....Thanks for the ideas....It may be a while, but I will report back when I am closer!
guitarjoem
And another Chicken Salad re-house...
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 51 times
Post by Hides-His-Eyes »
I'd love to see what you did with the guts of those. Did you replace the trimmers they use for pots or just make some kind of weird knob arrangement?
archimedes
Post by archimedes »
Here's mine done recently and sounding very fine indeed, I have discovered that it is great for those Paul Barrere / Little Feat type rhythm parts amongst other things. Paint is that Hammerite hammered finish stuff which you can apply directly to bare metal, I didn't want to spend too much time on finishing and I had it lying around from painting the kid's climbing frame about 18 years ago, it works well I think. No labels as yet, not sure that they will take to the finish or that I really need them.
In answer to the previous post, the two Dano pots and the trim pot have been removed and the pots on top of mine are wired direct to the PCB. The input / output and switching board has been removed completely.
guitarjoem
Hides-His-Eyes wrote:I'd love to see what you did with the guts of those. Did you replace the trimmers they use for pots or just make some kind of weird knob arrangement?
Like most everybody else, when I do a Danelectro rehouse I lose the board with the switching circuit and jacks and build a voltage divider, put in a 3PDT switch and new jacks. I also install new pots all the way around, and on the chicken salad I add reflective foil into the bulb's box. The stock board mount pots are super cheap and easy to break. The only original part is the circuit board that has the effect circuit. Some other Danelectro pedals use the switching board for more than switching, in and out jacks and power, so be careful before charging into a rehouse.
jgmcd
Post by jgmcd »
I am interested in finding that Hammerite finish in that same color for a pedal I am building right now.
What is the name of the color or color code for the color you used?
Did you use brush-on or aerosol?
blooze_man
Post by blooze_man »
It would be really cool to see some gut shots of these.
Winther
my favorite amplifier: Hiwatt, Laney, Fender, vox...
Completed builds: Plexitone, AC-Tone, DC-Drive, Opto-Comp, drivesection of the Quattro, inputs on the Echotone, Classic Flanger, Classic chorus....all together with the real mind behind those things, Thomas Guldmann.....I am just the ears and second opinion.
Modded a few Tubescreamers, one YJM DOD drive, a few Blues Drivers, one Ibanez Metal Charger, destroyed a huge number of pedals as well...haha
Post by Winther »
Stuffed mine today...
No gut shots.....hehe it looks awful hehe
