[stripboard] Tube Screamer
Been thanked: 909 times
Finally! I was trying to make that happen like ages now. Well made TS stripboard is really hard to design, specially to me. It isn't possible to make one without jumpers (as well as most IC based FX's). For some reasons I don't like jumpers, so all my entries to design it was instantly trashed. The other main reason is... well... I hate OD/Distortions in general, I'm a booster/fuzz bloke.
Tubescreamer is a part of music history, almost as much iconic as all well known and loved users by over last 30 years, on top with my personal hero SRV!
Anyway... It's done now, and I do quite like it. I couldn't get away with jumpers (I use 0-ohm resistors instead) but it's still quite nice. Doing this I had couple purposes in mind. Firstly - all none polarized caps at 5mm raster (two stripboard rows) and Panasonic SMF's as a type of my choice. 100uF and 47uF's the same - 5mm raster. Why so big? AM Silver Modded TS uses Sanyo OsCon type caps, and those values I have are 5mm raster. The other E-Cap (10uF) is 2,5mm radial, so standard stuff here.
What else... ah, yeah! The size :) Will easily fit into small B sized Hammond (or similar) enclosure. I was going to make it for 125B really, it's similar size to real TS-9, that's why my layout shows ins and outs in upper position, nor side located. I'll go with 125B anyway, as I have some evil plans for this project. Of course I won't shy to show of.
Few more things needs to point out:
- Transistors. Originally seen 2SC1815 low quality noisy Q's was changed to accommodate more ordinary pinout wise, and better quality in general 2N4401 transistors for in/out buffers, as recommended by GGG instructions.
- Optional Clipping Diode Switch pads are shown for future project extension, but you can easily crank yourself what it is, and what it does
- One none original part to standard TS series in input pull-down (anti-pop) resistor (2M2)
Two layouts for classic exemplars are attached:
Ibanez TS-808 Tube Screamer
Ibanez TS-9 Tube Screamer
As we all know, TS series was, and still is Poo-Teeque Cart-Horse, so expect shitload of variants very soon here and on my website
Duckman
Has thanked: 320 times
Been thanked: 134 times
Post by Duckman »
Nice and neat as always! :applause:
Maybe a silliness, but I noticed that 51k resistors have the same color code of 510k's.
Bancika, are you there or I'm going color blind? :lol:
Duckman wrote:Nice and neat as always! :applause:
Sometimes they look similar when I change alfa, but it's as it say on the body :)
Thanks a lot, you're too nice ;)
Duckman
Post by Duckman »
Ah!... alfa... it's ok.
Well, I'm just curious, because when a run the program, all colors are ok :thumbsup
I always do my layouts in alfa, for some reason it's more clear to me
Anyway, as I said I'll do more TS exemplars and variations, and also I'll upload the .diy file - that way you guys can do your own (change and move stuff as you wish)
I'm on training in different city by next couple of days (fucking Euro fest), so I'll do it as soon as I back
beedotman
Has thanked: 402 times
Been thanked: 394 times
Post by beedotman »
Great layouts! :thumbsup
beedotman
Post by beedotman »
I have somwhere pretty nice stripboard layout for Son of Tube Screamer - simplified TS without input and output buffers. I must to redrawn it in DIY, becouse I lost all my works when HDD died :slap: and I haven't any backup, but will try do do it during weekend and post here :D
Go for it girl :)
beedotman
Post by beedotman »
Here it is!
sots.pdf
(53.6 KiB) Downloaded 169 times
Dude... Really nice layout!
beedotman
Post by beedotman »
And here layout for Son of Clay Jones Overdrive based on Fred Briggs schematic:
socj.pdf
(53.23 KiB) Downloaded 143 times
beedotman
Post by beedotman »
And here with added Bass knob (nickled from Timmy pedal) and switchable clipping section. :blackeye
socj_bass.pdf
(69.3 KiB) Downloaded 151 times
beedotman
Post by beedotman »
sinner wrote:Dude... Really nice layout!
Thanks! :hug:
Seiche
Has thanked: 231 times
Been thanked: 189 times
Post by Seiche »
You two are crazy! Those layouts are very stylish. Makes me want to build another TS. So much other work to be done though.
beedotman, that timmy/C-jones mashup is awesome! great work!
care to share which font you used on the layout? Looks really cool :)
Seiche wrote:You two are crazy! Those layouts are very stylish.
You're too nice Seiche
roseblood11
Has thanked: 366 times
Been thanked: 314 times
Post by roseblood11 »
A few variations of the TS:
- my "Rose Screamer" (use 4580 for IC3!)
- Ibanez ST-9 (unverified, read the thread...)
- TS-9 and SD-1 on one board, using a 4136, the quad version of the 4558
Nice dear Sir :thumbsup
beedotman
Post by beedotman »
Seiche wrote:You two are crazy! Those layouts are very stylish. Makes me want to build another TS. So much other work to be done though.
Thanks, mate! :thumbsup
I don't remember font name - will check after work and let You know.
beedotman
Post by beedotman »
roseblood11 wrote:A few variations of the TS:
This Rose Screamer looks great, will put it on my workbench in time, for sure :thumbsup
roseblood11
But that's not the Rose Screamer... :wink:
