4 wire connector
gkterry
Post by gkterry »
Anyone have a recommendation for a 4 wire connector set used to link a footswitch pcb to the main pcb? Typically I have seen one mounted on the main pcb & the other used on 4 wires coming from the footswitch pcb. Part numbers & vendor would be appreciated.
phatt
Been thanked: 343 times
Post by phatt »
Welcome,
Sadly we don't use mental telepathy here so a picture of the connector in question along with a brand and model number might help you get better results. :wink:
Cheers, Phil.
aishabag23
Has thanked: 85 times
Post by aishabag23 »
gkterry wrote:Anyone have a recommendation for a 4 wire connector set used to link a footswitch pcb to the main pcb? Typically I have seen one mounted on the main pcb & the other used on 4 wires coming from the footswitch pcb. Part numbers & vendor would be appreciated.
Maybe these?
http://www.taydaelectronics.com/connect ... minal.html
Loe Sounds
