Keio - Synthesizer Traveler  [schematic]
Postby Dirk_Hendrik » 07 Aug 2010, 14:21
For this one I've had many requests, sorry for the long delay Boris) and since I'm off next week here's something to chew on.
Which one was that again? This one, the pedal aiming for the title "biggest off em all"
http://www.dirk-hendrik.com/images/keio.jpg
and http://www.dirk-hendrik.com/images/keio_inside.jpg
I'll post the PCB layout next week, including component placement. Here's the schem for a warmup:
http://www.dirk-hendrik.com/temp/keio_synthesizer_traveler.pdf
For this message the author Dirk_Hendrik has received thanks:
snk (13 Jun 2019, 21:21)
Has thanked: 255 times
Have thanks: 1035 times
Re: [SCHEM] Keio Synthesizer Traveler
Postby borislavgajic » 07 Aug 2010, 16:34
........no man ..I am sorry if I was pushing too much :lol: year after year :D :oops:
Thank you Mr Dirk for your time and effort :thumbsup :hug:
Boris
borislavgajic
Has thanked: 140 times
Have thanks: 252 times
Postby Dirk_Hendrik » 07 Aug 2010, 18:09
Thanks laddie. Knew I could count on you :hug:
Other than that, I had to. The thing is really acting up weird. Poor contacts, cracking wiring, name em. Drawing up a schem is step one in a full overhaul.
Postby John Lyons » 08 Aug 2010, 00:34
Are there any recorded examples I can check out?
John Lyons
Have thanks: 26 times
Postby celadine » 08 Aug 2010, 04:37
Thanks Dirk! Thats a weird one, especially the wah/singing. No wonder they called it 'synthesizer', its like 8 pedals in one.
celadine
Has thanked: 16 times
Have thanks: 16 times
Postby gigelmargel » 31 Aug 2010, 16:49
Very interesting project, Dirk! Thanks a lot for it!
I will give it a try as soon as you will post the PCB...:)
gigelmargel
Has thanked: 17 times
Have thanks: 15 times
Postby Dan N » 02 Sep 2010, 23:17
Thanks very much, Dirk!
Hmmm, guess it's so rare no body has even demoed one on youtube. The Jacques "Singing Geisha" is supposed to be a clone, but can't find a sample of one of those either.
Dick joke has expired.
Dan N
Has thanked: 57 times
Have thanks: 20 times
Postby Dirk_Hendrik » 09 Sep 2010, 21:26
oops..made a promise
red components are added on the pcb solder side.
Postby gigelmargel » 09 Sep 2010, 22:04
Very kind, as usually, Dirk!
Thank you very very much :)
gigelmargel
Postby borislavgajic » 10 Sep 2010, 09:03
:applause: :hug:
borislavgajic
Postby SPeter » 11 Sep 2010, 18:17
:applause:
:thumbsup
:D
SPeter
Have thanks: 76 times
Postby noelgrassy » 12 Sep 2010, 18:15
Nice job Dirk, thank you! I've never seen or much less heard one of the puppies so it'll
be a fun project to put one together. Does anyone see obsolete parts that may make
the BOM a bitch to fill?
Why "Traveler" I wonder? Or am I confusing a sojourner [i.e. Kwai Chang Kane] with the treadle action? :hmmm:
Noel Grassy.
noelgrassy
Have thanks: 3 times
Postby John Lyons » 13 Sep 2010, 01:37
Yeah, interested to hear this one.
John Lyons
Postby RickL » 18 Sep 2010, 06:07
I assume the posted PCB layout is the origional? If so, I see some differences between the schematic and the layout.
1) R13 (47k) and R14 (68k) are switched from the schematic to the layout. Which is correct?
2) R1 is 100k on the layout, 1M on the schematic. Which is correct?
3) R26 is 2k2 on the layout, 47k on the schematic. Which is correct?
4) Pads 4 and 6 (counting from the left on the layout) are not connected on the layout, they are on the schematic. Are the the two points connected with a wire on the actual unit?
I'm ready to build this as soon as I know the correct values. I'll assume that generic NPN and PNP transistors will work as long as the pins are connected correctly.
Rick
RickL
Postby Dirk_Hendrik » 18 Sep 2010, 09:18
RickL wrote:I assume the posted PCB layout is the origional? If so, I see some differences between the schematic and the layout.
Rick
Thanks for the attention.
I'll check later. Gotta buy a house first.
Postby borislavgajic » 19 Sep 2010, 12:44
hey Dirk.....your place got too small for all pedals you have? :thumbsup :lol:
happy housing !
Boris
borislavgajic
Postby RickL » 09 Nov 2010, 07:18
I couldn't wait so I built this. I used the values on the layout, not the schematic, subbed the transistors with other 2SC and 2SB units and guessed a bit on the wiring of the switches and pots.
The fuzz works, the wah works, the bypass works, the Traveller works (seems to just be a passive volume control that operates when the fuzz is bypassed) but the singing does nothing.
Operating the Singing switch just seems to switch the wah in and out. Neither the Peak nor Singing pots have any effect in either position of the Singing switch. R19 (trimmer) affects the resonance of the wah.
I've experimented a bit with the wiring of the wah pot and the Singing switch with no luck.
Anyone have any ideas?
For this message the author RickL has received thanks:
modman (11 Apr 2017, 14:14)
RickL
Re: Keio - Synthesizer Traveler
Postby modman » 11 Apr 2017, 14:15
found some pictures and gut shots
Has thanked: 3279 times
Have thanks: 611 times
Users browsing this forum: skint and 5 guests
