Electrolab - Fuzz Buzz [guts][schematic]
Found this while surfing the web, never heard of this and it looks interesting. It looks like a somewhat different design (not a fuzz face or tonebender at least) thought someone here might be interested. Trying to contribute something here since i lurk all the time. I hope someone can benefit from this.
- devastator
Nice !
Doesn't look like a meastro or tonebender schematic posted on DAM forum ? (fz1 or something like that I think)
the switching system looks bizarre, it put the ouptut at ground on "off"
it does look strange, from the schematic it looks like one switch mutes the pedal and the other cuts power
maybe to save the battery without disconnecting the input jack? only thing i can think of.
also now that i'm looking at it a little more it could be similar to a maestro FZ-1, I'm basing this off the 1.5V supply
- lolbou
Yes, but to achieve a "no sound when off" pedal, only the power switch is enough.davidgiandiletti wrote:maybe to save the battery without disconnecting the input jack? only thing i can think of.
Why two?
WHY TWO??
(your next stop: the twilight zone....................... )
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
- B Tremblay
Very interesting. I acquired a Lectrolab amp a few years back and had never heard of that manufacturer at that time. That fuzzbox is certainly in nice condition.
- Electric Warrior
It's exactly the same circuit topology.davidgiandiletti wrote:also now that i'm looking at it a little more it could be similar to a maestro FZ-1, I'm basing this off the 1.5V supply
- mictester
Looks like the Maestro FZ1 to me. It mangles the signal by messing with the bias for the second transistor. My very first fuzz design working a bit like that, but used silicon transistors.... Schematic to follow!davidgiandiletti wrote:Found this while surfing the web, never heard of this and it looks interesting. It looks like a somewhat different design (not a fuzz face or tonebender at least) thought someone here might be interested. Trying to contribute something here since i lurk all the time. I hope someone can benefit from this.
- Electric Warrior
actually the FZ-1 was the 3V version. The FZ-1A is the 1.5V one.
The Lectrolab has a .0047 cap at the output instead of a .0033 one. That's the only difference.
i figured if it were anything too unique and still decent sounding it would've already been discovered. if nothing else its a nice gut shot.
- Alex Frias
Could it be possible to tell us the transistors code?
- Electric Warrior
better than retro: it's vintage!bootle wrote:love the retro look/design of this pedal,
cheers for posting it!
- D-Day
- Mojo Book Buster
It's almost as if these guys hold $300 boutique dudes who have fancy hakko soldering stations, teflon insulated wire, circuits designed by or based on the work of others, custom through plated PCB's, photographic reference of the work of thousands before them and the internet to read from, ask questions of and source any part or tool under the sun to kind of a different standard than some low wage factory worker trying to cobble together a cheap fad item a few years after the dawn of the transistor.Cups wrote:If this was a boutique builder you cats would have been all over this as being "badly soldered" and "sloppy".
A-holes imo
- RnFR
