Colorsound - Chuck-A-Wah [schematic]
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 281 times
no thread about this onem (two versions to be correct)
can someone post some guts??
http://www.effectsdatabase.com/model/co ... /chuckawah
Boris
Boris
- Nocentelli
- Has thanked: 1155 times
- Been thanked: 954 times
I'm guessing you've seen these schematics?
I've no idea how accurate they are...
- borislavgajic
- Opamp Operator
Nocentelli wrote:I'm guessing you've seen these schematics?
thanks I saw that............so therefore I need to see some gutshoots....looked on net, but none to be found
- DiscoFreq
I have one...
EffectsDatabase: http://www.effectsdatabase.com
22000 pedals, 4000 brands, 350 brand interviews
NAMM 2016: http://fxdb.org/namm
- borislavgajic
- Opamp Operator
Bart I know you are busy.....but if I could ask for some guts please?....when ever you find time.......there is nothing on net,only those schems ..........DiscoFreq wrote:I have one...
thanks
Boris
- DiscoFreq
Next time I see the pedal I'll take some pictures (could take a while)borislavgajic wrote:Bart I know you are busy.....but if I could ask for some guts please?....when ever you find time.......there is nothing on net,only those schems ..........DiscoFreq wrote:I have one...
thanks
Boris
Hi
Could I have a guts shot of them both [please-trying to restore one and would like to stick to correct layout and components
many thanks all
VM
many thanks all
VM
Hey man, I've just restored one too!
There is some good info here, including guts shots: http://www.effectsdatabase.com/model/co ... /chuckawah
And here's my pedal:
And here some schems:
I hope that helps! Good luck!
G'day, I'm Marcus ♫ mwynwood.com ♫ Pictures of my Builds
- Bernardduur
How does it sound?
- Bernardduur
Nice; sounds really jumpy
Sorry man-forgot about this site, and for some reason not linked - is now#
That looks and sounds great. are the schematiccs accurate, Ive had some instability issues with mine-but Ive not put it such a cool box
Ill box it and post pics
Thanks again
Thanks again
Hi
Ive been playing around with layout for this-but cant get it close enough to the original-just wondered if anyone had done a PCB layout for thisplease?
Ill post mine soon when its finished-and se how close it is
Cheers all
Cheers all
Here it is-forwhat its worth
Just a start-too many links-I will add comp numbers later
Cheers all
Cheers all
- ChukPCBImage.bmp (582.24 KiB) Viewed 2203 times
