Oberheim - VCF-200 pedal (sample & hold - filter)
One of my favourite pedals..mine died in the 70's and I couldn't find a tech in Sydney that could fix it
None of the digital simulations quite have the same analog 'thwack' as the originals
(listen to Zappa's solo on 'Ship Ahoy' for a good demonstration)
Anyway..I couldn't find one on the forum which I thought was a glaring omission
If someone has copied this, I'd like to know about it
Link to Matrixsynth info page
http://matrixsynth.blogspot.com/2011/05 ... er-sh.html
Cheers, squatch
Cheers, squatch
squatch, I'm working on a clone, I design my own PCB for it, and it is in the prototype fase at the moment.
It is working just the way it should ( I had an original Oberheim my self, sold it last year). the sound of the thing is very dependable on the transistor used for noise generation, so you have to sort a lot of them.
Here a picture how it looks now:
Maybe I will sell these in the near future, I fist have to find good sourcing for all parts and a nice design for the housing.
Cheers Peter
Cheers Peter
- Zokk
What are the differences between this one and the FSH1 from Maestro (which was built by Oberheim anyway)?squatch wrote: If someone has copied this, I'd like to know about it
Is it based on a CA3080 too?
The only difference is the housing, both uses the same board. And yes they are based on the 3080.Zokk wrote:What are the differences between this one and the FSH1 from Maestro (which was built by Oberheim anyway)?squatch wrote: If someone has copied this, I'd like to know about it
- Zokk
Thanks for confirmation pdhoed.
So squatch, you should have a look at the tonepad page... their clone uses the LM13600/LM13700... and I think it's even possible to use a NE5517 as it's compatible pin to pin...easy to source and a lot cheaper than the 3080!
Hey thanks Peter & Zokk!
BTW I'm just a guitar tech that can solder so I wouldn't attempt a build
But my synth tech could build one (if I don't get one from Pete...heh)
Thanks again guys
Thanks again guys
- Whoismarykelly
The noise source is absolutely key in determining the frequency range and "randomness" of the filter. A really noisy 2n2222 for example tends to get locked on certain frequencies which gives the pedal a really unique electronica sound. Something more even gives the classic pulse. Buffering the front end is an easy way to kill off any tick.
- grrrunge
Tonepad has made an exellent board available for us DIY'ers see my comments on the project here: https://www.freestompboxes.org/viewtopic ... 19&t=16673squatch wrote:If someone has copied this, I'd like to know about it
