red and violet can be confused..... so the schematic values appear to be right.420R? is 470R is schematic - taking into account 10% tolerance
42R will be 47R - idem
Blue green Gold Gold would be 5,6 Ohm.....Blue Green Gold Gold indeed 6.8 Ohm, as noted in schematic
Crazy the 6,8 (5,6) Ohm resistor, if it would be 680 Ohm or 6k8 it would make sense. 6,8 Ohm is useless and can be jumpered.
That´s not a big question: It is near pin 1 of the chip.But the big question is where is the 10k resistor that -according to the schematic- should be connected to the parallel 10uF + 12k?
Nobody knows why he used a 100n ceramic cap for input coupling when he used 100n film caps in the filter section.
Alltogether the schematic appears to be right.
Compare it with the Doctor Q and Bassballs schematics and you will see that a 2N5088 will do it.
