Germanium Fuzz Face Hiss With Guitar Volume Rolled Down.
Ripdivot
Been thanked: 78 times
Post by Ripdivot »
I have searched for an answer for this but haven't had any luck. I have a germanium fuzz that I built years ago and I have always had the following problem. The fuzz (hiss) is normal with my guitar volume up all the way but when I roll it back I get hiss. The farther I roll the volume down the more hiss I get. Here is the kicker, I only get this hiss when I use a power supply. I have tried a regulated boss supply and my voodoolab pedal power plus supply. I am not using any other pedals. When I run it off a battery this hiss does not happen so I use a battery. I would like to be able to use a supply. I have tried several other fuzzes and some have this issue and some don't. Any ideas? :scratch:
LucifersTrip
my favorite amplifier: Companion Psychedelic Machine
Completed builds: Mosrite Fuzzrite (Si), Mosrite Fuzzrite (Ge)[2], Get Lo-Fi Fuzz, Fuzz Face (Ge) [2], Fuzz Face (Si) [3], Mos-Face, Vox Tone Bender, Kay Tremolo, Os Mutantes Fuzz [2], Psychedelic Fuzz, Smokey Amp, Sunn Buzz, Jen Fuzz, Fancy Fuzzbox, Muff Fuzz (op amp) [2], Buzz Box, Fuzz King, Rangemaster [5], Maestro FZ - 2/3, Ruby Amp, Orpheum Fuzz (Ge) [4], Great Destroyer, Schizo, Carlsbro Suzz, Shin-Ei Companion Fuzz (si), DOD 250 Gray [2], Super Dirt Fuzz, Fuzz Factory, Jordan Boss Tone, Sam Ash Fuzzz Boxx, Heathkit TA-28 Fuzz, Olson New Sound Fuzz, LRE Fuzz Sound, Green Ringer, Vox Super Beatle (Ge), Colorsound One Knob (Ge), Demon Buzzz [2], Demon Wasp v1, Demon Wasp v2, Super Hard-On, Bazz Fuss, Burns Buzzaround [2], Selmer Buzztone, Shin-Ei Companion Fuzz (Ge), Fuzz Face/FY-2 (Ge), Zonk Machine, Univox Squarewave, Demon Fuzzz, Mosrite Fuzzrite BG-500/1000 (Ge), Univox Superfuzz, Marshall Supa Fuzz, Demon Monster, AA Overdrive/ Retro Fuzz, Tone Bender MKII, Psychtar, Jordan Vica Vibe, etc...
Has thanked: 19 times
Been thanked: 71 times
Post by LucifersTrip »
try a 100 ohm resistor coming in in series on the power supply rail
there is a small possibility that may not be large enough. so, you could put a 500 ohm pot in series with the power, start at zero, then increase until hopefully the hiss disappears
https://www.diystompboxes.com/smfforum/ ... #msg813123
I've had that problem on tone bender mkii's and green ringers
Ripdivot
Post by Ripdivot »
Tried the 100 ohm resistor and it didn't help. Tried all the way up to 470 ohms and no change. The problem I have is not power supply hum or ripple on the supply. My issue is hissssss when I roll the guitar volume pot down to clean up the fuzz. The more I roll the vol back the louder the hiss gets. The hiss is very loud when the guitar vol is down all the way. No hiss if I just use the battery.
Ripdivot
Post by Ripdivot »
Tried the 100 ohm again and it worked. I must have had it soldered in wrong the first time. Thanks for the response LT! :thumbsup
LucifersTrip
cool...with vintage effects that didn't originally use an adapter, it's always good to see if there's a difference with a battery or 100ohm.
you can get hiss, degraded sound, lower volumes or any combination
