Sekova - Fuzz ( FA-II , Apollo , Crestwood )
Postby analogguru » 31 Mar 2008, 10:59
An interesting Apollo Fuzz up for sale:
http://cgi.ebay.com/APOLLO-PEDAL-VINTAG ... 0228514860
The intersting thing is the case looks like a Maestro Fuzztone clone - inside it doesn´t match with the Sekova´s or anything else - especiallybecause there are 2 Ge-diodes visible.
Any infos are welcome,
Have thanks: 116 times
Re: Apollo - Fuzz
Postby MoreCowbell » 31 Mar 2008, 17:22
2 Ge diodes, 7 electrolytics, what "looks like" 2 Ge transistors, 12 resistors, 1 film cap, 1 unidentified part (white cap transistor ?)....
It doesn't match any circuit I can think of.
The electrolytics look like new replacements.
MoreCowbell
Have thanks: 11 times
Re: Apollo - Fuzz
Postby MoreCowbell » 02 Apr 2008, 16:56
it looks like the crestwood fuzz ...
MoreCowbell
Re: Apollo - Fuzz
Postby royaltoots » 05 Nov 2008, 13:10
I just got one like this that is badged Sekova in the usual chrome wedge ('cept the Sekova badge is mssing, so can't be 100% sure, but def from the same source) - Sounds nothing like a Fuzztone.
It has 2 x 2SB173 Matushita PNP germs, the white thing is a tant.
It's 9V, but slighlty different to other 9V Sekovas I've seen online. Here's another pic:
More detailed pics, inc the underside of the pcb, soon.
royaltoots
Have thanks: 4 times
Re: Apollo - Fuzz
Postby DiscoFreq » 05 Nov 2008, 14:54
I have a black fuzz (no brand label) like this too. I thought it was a painted Sekova, but then I got a Sekova and saw that the circuit was completely different...
Here's a picture of a "normal" Sekova:
http://filters.muziq.be/model/sekova/59
EffectsDatabase: http://www.effectsdatabase.com
22000 pedals, 4000 brands, 350 brand interviews
NAMM 2016: http://fxdb.org/namm
DiscoFreq
Have thanks: 25 times
Re: Apollo - Fuzz
Postby royaltoots » 07 Nov 2008, 11:35
this post on the DAM forum has detailed pics, as well as referring back to here.
http://www.stompboxes.co.uk/forum/viewtopic.php?f=23&t=525
royaltoots
Re: Apollo - Fuzz
Postby analogguru » 07 Nov 2008, 12:26
I have seen a unit where a film cap was used instead - approx 220n from the size.
Interesting circuit - component values would be appreciated to finish the schematic. The unit appears to be produced in mid-1969.
BTW, the input jack appears to be not original.
Re: Apollo - Fuzz
Postby royaltoots » 07 Nov 2008, 22:27
values
R1 - 27K
R2 - 100R
R3 - 15K
R4 - 5.6K
R5 - 5.6K
R6 - 27K
R7 - 5.6K
R8 - 15K
R9 - 5.6K
R10 - 22K
R11 - 22K
R12 - 68K
C1 - 10uF
C2 - 10uF
C3 - 33uF
C4 - 33uF
C5 - 10uF
C6 - 10uF
C7 - 10uF
C8 - unknown poly
C9 - unknown tant
C10 - 0.001uF
Q1, Q2 - 2SB173
D1, D2 - Ge diodes
input jack moved? yeah - input originally hardwired, as on the Fuzztone. 1969? from the caps?
For this message the author royaltoots has received thanks:
modman (05 May 2015, 08:17)
royaltoots
Re: Apollo - Fuzz
Postby analogguru » 08 Nov 2008, 00:31
Thanks for the values.
From the size I would say that it is a 100nF which should have printed "104" or ".1" on it (in black or in silver). Maybe it is smaller thenthis would be "473" or ".047".
The tantalum is in another unit a film capacitor in the size between 220n and max. 470nF. The tantalum has color dots on the side to C8. Maybe you can identify them ? red/red/yellow would be 220n .
Still missing are the potentiometer values.
Re: Apollo - Fuzz
Postby royaltoots » 08 Nov 2008, 13:23
Hi again
the film cap is probbaly 100nF, the printing is faint but I can now see 100 and a strange symbol which I think is a maker's mark - looks like this:
tant has 2 dots only I can see - red + black
forgot the pots - they are Attack 500K Lin, Vol is switched Fuzztone type, 50K Lin
also - a drawing to clarify wiring:
royaltoots
Re: Apollo - Fuzz
Postby analogguru » 08 Nov 2008, 14:34
I think this is the voltage rating: 100V
Typical markings for 100n mylar caps can be seen in the picture below.
50k for the volume pot appears to be a bit low when the attack pot is 500k :hmmm:
Re: Apollo - Fuzz
Postby royaltoots » 08 Nov 2008, 15:04
no other visible markings on the cap, must be on the side closest to the switch...
on-off vol pot is defnitely 50K.
royaltoots
Re: Apollo - Fuzz
Postby RnFR » 09 Nov 2008, 07:06
analogguru wrote:[quote
this is similar to DIY copies of the mosrite fuzzrite. the original had a 33K/350K setup.
Has thanked: 150 times
Have thanks: 174 times
Re: Apollo - Fuzz
Postby analogguru » 09 Nov 2008, 11:22
That´s a valid argument, but it doesn´t take into account, that he tone control is completely different there.
For the interested ones I made some frequency plots, assuming the one capacitor to be 100n and the other one 220n.
If you increase the 220n to 470n only the bottom end below 40Hz becomes more flat - neglectable. black dot/red dot may also show 0.2 µF.
the freq-plots for the attack control are arranged as follows:
first-half attack pot value (from 1n cap) - second-half attack pot value (from 220n cap) - vol-pot value.
There are three sets:
500k attack-pot - 50k vol-pot
500k attack-pot - 500k vol-pot
50k attack-pot - 50k vol-pot
enjoy,
Re: Apollo - Fuzz
Postby royaltoots » 09 Nov 2008, 11:43
I don't know enough to interpret the charts, but regarding the tone control - instead of a standard treble bleed to ground, I think it pans between two caps, like the BMP (and Orpheum fuzz) tonestack - smallest one is 0.001uf and fully rotated this sounds a bit Superfuzz-bumblebee-like, but with a drop in volume as the the cap cuts most of the output to get this sound. At the opposite end of the sweep, it's al lot louder, very bassy and with all the fuzz gone.
royaltoots
Re: Apollo - Fuzz
Postby analogguru » 09 Nov 2008, 13:23
Do the 2SB173 have a suffix (-B, -C or -D)?
And the attack control is really 500k ?
Re: Apollo - Fuzz
Postby royaltoots » 09 Nov 2008, 17:57
analogguru wrote:Do the 2SB173 have a suffix (-B, -C or -D)?
ok - the transistsors have an A suffix in a circle a little distance away from the part number - underneath it on Q1 is the letter S in a red dot, and on Q2 an X in a red dot.
the Attack control is definitely 500k, very clearly printed.
royaltoots
Re: Sekova - Fuzz ( FA-II , Apollo , Crestwood )
Postby analogguru » 09 Nov 2008, 19:33
Ok, then here is the final
Sekova Fuzz (FA-II) schematic
Circuit and frequency-plot discussion follows later when I find some time.
Re: Apollo - Fuzz
Postby RnFR » 09 Nov 2008, 19:43
analogguru wrote:That´s a valid argument, but it doesn´t take into account, that he tone control is completely different there.
well we haven't seen a schematic yet have we? :wink: ****edit*** - you beat me to it!
thanks for the plots. should be helpful for reconstructing this circuit. the 500k/500k looks like it might be a bit more useful- doesn't have such a massive mid scoop. just an initial guess though. i know my frequencies, but don't have much experience reading these charts as they pertain to stompboxes.
**edit again- looks like the 500k/500k might have more output on the scooped side as well?
and thanks for the schematic!
Postby royaltoots » 09 Nov 2008, 19:49
great - thanks!
royaltoots
Next
Users browsing this forum: No registered users and 8 guests
