Sekova - Fuzz ( FA-II , Apollo , Crestwood )
Re: Sekova - Fuzz ( FA-II , Apollo , Crestwood )
Postby RnFR » 10 Nov 2008, 00:14
I just made a vero layout for this pedal. of course it is not yet verified, but it looks good to me. i haven't put the values of the parts up yet, but the part numbers match AG'S schemo. if anyone builds it, make sure to let me know so we can get it up in the ready to build pages.
oh yeah, i added a power filtering cap- C11.
Has thanked: 150 times
Have thanks: 174 times
Postby analogguru » 10 Nov 2008, 01:29
Funny, on my HD I found guts where the diodes are silicon, the 27k resistors are 33k and the 5k6 resistors are 4k7. The pcb has also minor differences.
On these guts the capacitor which was in doubt is a 100n as I expected. The tantalum is a film cap.
Have thanks: 116 times
Postby royaltoots » 10 Nov 2008, 13:46
analogguru wrote:Funny, on my HD I found guts where the diodes are silicon, the 27k resistors are 33k and the 5k6 resistors are 4k7. The pcb has also minor differences.
On the old DAM forum Andy/MoreCowbell posted this pic of a 9V Sekova, is it this one?
more - http://dam.10.forumer.com/viewtopic.php?t=1439&highlight=sekova
royaltoots
Have thanks: 4 times
Postby analogguru » 10 Nov 2008, 14:27
Yes, that´s the one.
Postby gigelmargel » 20 Jul 2009, 08:51
Hello,
I've just finished one of this using some SFT242 with gain between 70 and 90 and it sounds pretty OK, but I am not sure if it's as the original or not.
My voltages, using a 8.70 battery, are:
Q1: C = -5.75 B = -3.08 E = -2.95
Q2: C = -5.70 B = -3.03 E = -2.93
R4/R5 node: -0.06
Anyone can tell me if these voltages are OK or not?
Thx a lot !
For this message the author gigelmargel has received thanks:
modman (05 May 2015, 08:24)
gigelmargel
Has thanked: 17 times
Have thanks: 15 times
Postby RnFR » 22 Jul 2009, 14:45
i've got a silicon version of this on the breadboard now. i made some mods including an extra booster stage for more volume, diode switch, and i adjusted the bias a bit. later today i'll try to make it stock, pop in some Ge's, and test the voltages for you.
Postby gigelmargel » 23 Jul 2009, 16:36
RnFR wrote:i've got a silicon version of this on the breadboard now. i made some mods including an extra booster stage for more volume, diode switch, and i adjusted the bias a bit. later today i'll try to make it stock, pop in some Ge's, and test the voltages for you.
Thx a lot RnFR!
What silicon transistors did you use?
gigelmargel
Postby RnFR » 23 Jul 2009, 21:23
i used a 2n5087 into a 2n2907, but that's pretty much because i was set up for PNP because i tried it first with Ge transistors. i personally like this circuit better with silicon. you could try an NPN version with an 2n5088 into a 2n222 and it would probably be close. i messed with R6 a bit, too. i think i changed it to 3K9 or 4K7. that took care of any gating that was happening. i added a simple Ge booster after the tone section, and pregain control at the front of the circuit as well. now it's plenty loud, there is a tone control, and a gain control as well as an on/off/on diode switch. much more versatile and usable in my opinion. i heard this pedal at midwest buy and sell here in chicago years ago and always kicked myself for not buying it. it does a great swarm of bees kind of tone. :mrgreen:
i'll try to get those voltages measured tonight, but i think the difference in our Ge transistors used will affect the readings. do you have some silicons like i mentioned above? that would probably solidify it a bit.
i'll try and get a schematic of what i did drawn up one of these days, too.
Postby gigelmargel » 23 Jul 2009, 21:38
RnFR wrote:i used a 2n5087 into a 2n2907, but that's pretty much because i was set up for PNP because i tried it first with Ge transistors. i personally like this circuit better with silicon. you could try an NPN version with an 2n5088 into a 2n222 and it would probably be close. i messed with R6 a bit, too. i think i changed it to 3K9 or 4K7. that took care of any gating that was happening. i added a simple Ge booster after the tone section, and pregain control at the front of the circuit as well. now it's plenty loud, there is a tone control, and a gain control as well as an on/off/on diode switch. much more versatile and usable in my opinion. i heard this pedal at midwest buy and sell here in chicago years ago and always kicked myself for not buying it. it does a great swarm of bees kind of tone. :mrgreen:
Thx a lot RnFR!
2N5087 it's impossible to find here, but I have some BC560 (or something like that)...booster I will not add because I used booster almost all the time, so that's not a big problem.
gigelmargel
Postby gigelmargel » 25 Jul 2009, 20:35
I replaced Q1 with a BC560, Q2 with a 2N2905 and the germanium diodes with silicon ones and it sounds better.
I will try in the next days to tweak it a little.
Thx a lot RnFR again for your advices!
gigelmargel
Postby RnFR » 04 Aug 2009, 20:08
gigelmargel wrote:I replaced Q1 with a BC560, Q2 with a 2N2905 and the germanium diodes with silicon ones and it sounds better.
you are very welcome! sorry i didn't get around to posting those voltages. try lowering the 5K6 collector resistors a bit. this helped get rid of some gating that i was hearing at the very final end of the decay. you might not be able to hear it with the diodes clipping, but without them it is very noticable.
also, i put a schematic up in the Ready To Build section with all of the mods i've done.
viewtopic.php?f=13&t=6885
For this message the author RnFR has received thanks:
modman (05 May 2015, 08:25)
Postby gigelmargel » 12 Aug 2009, 12:30
http://freestompboxes.org/viewtopic.php?f=13&t=6885
Thx a lot again! You're great man !
gigelmargel
Postby LucifersTrip » 24 Aug 2012, 10:25
sorry to dig up an old thread, but there was a question about whether it gates (yes)...the answer to the the low output volume was obvious (yes).
there's one on eBay now with a sound file:
http://thenoir.net/pedal-samples/sekova-faII-01.mp3
...of course, the gating could also simply be from degenerated / misbiased transistors...
For this message the author LucifersTrip has received thanks:
jrod (24 Aug 2012, 14:32)
LucifersTrip
Has thanked: 21 times
Have thanks: 85 times
Postby edkoppel » 29 Aug 2012, 15:26
I would say that is a pretty accurate audio clip.
not sure if it's anything you guys don't already have, but I did a blog post on a Sekova a few months back:
http://tonemachines.blogspot.com/2011/1 ... -1969.html
the strange thing is that is sounds extremely similar to the fuzz-side of the 6-tranny Shin Ei Fuzz Wahs, but doesn't seem to be related circuit-wise at all?
:hmmm:
Tone Machines: vintage effects blog:
edkoppel
Have thanks: 26 times
Postby GodSaveMetal » 05 May 2015, 01:19
analogguru wrote:Ok, then here is the final
Sekova Fuzz (FA-II) schematic
Circuit and frequency-plot discussion follows later when I find some time.
Please man can you repsot the circuit of the versions of SEKOVA FUZZ? great man!!!
GodSaveMetal
Has thanked: 141 times
Have thanks: 53 times
Postby d312a » 05 Jul 2015, 09:32
I found this schematic
Some values in the tone section is incorrect:
1nF shold be 2,2nF
1uF should be 100nF
1,2 should be 220nF
I have built several variants of this circuit and IMHO it sounds better without the diodes.
I also increased the volume pot 500kB to increase the output level.
d312a
Has thanked: 68 times
Have thanks: 9 times
Postby d312a » 05 Jul 2015, 09:35
Ooops, don't know how to ad images or edit post to the forum so here is the link to the schematic
https://78462f86-a-87c6d4c2-s-sites.goo ... edirects=0
d312a
Postby GodSaveMetal » 05 Jul 2015, 14:25
d312a wrote:Ooops, don't know how to ad images or edit post to the forum so here is the link to the schematic
Please man you would post the lay+PCB you have build?? thanks a lot, it´s awersome you post!!!
GodSaveMetal
Postby dukeofearl » 16 Feb 2019, 18:25
Sorry to reactivate this very old thread! I've been searching for info on this Sekova FA-II pedal and haven't had any luck.
I'm not sure but there appear to be 3 film caps on mine. Maybe some are tantalums? One of these capacitor leads is broken. The other two look fuzzy. I was hoping to replace these but can't find values. Any suggestions?! Thanks!
dukeofearl
Postby dukeofearl » 16 Feb 2019, 18:27
one more pic...
For this message the author dukeofearl has received thanks:
george giblet (29 Mar 2019, 05:45)
dukeofearl
