EHX - Deluxe Octave Multiplexer
- Bernardduur
Wasn't this model the only full wave octaver (or something like that????)
I know I read an interview with the person who designed it and he was very proud of it.
Also, the bass player of magic dirt uses one for his main fuzz tones and it sounds great
- marshmellow
AG you're right, on the top side they are both 1N3666.
The diode attached on the solder side is barely readable, but I can desolder it if you really need it.
- uncleboko
It contains the front end of the rackmount guitar synth does it not? So it has a pretty decent fundamental generator - 2 x CA3094 so not surprising that it is good!Bernardduur wrote:Wasn't this model the only full wave octaver (or something like that????)
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 281 times
....wow....great........!!!....could you make trace side pictures like if you put PCB on scanner?...it is a lot easyer to clone pcb in that waynoise31 wrote:yeah..i have this pedal,,,,it´s great,,,,,
I take pics and post soon......
thanks.....I can't wait to see
boris
- himister
borislavgajic wrote:....wow....great........!!!....could you make trace side pictures like if you put PCB on scanner?...it is a lot easyer to clone pcb in that waynoise31 wrote:yeah..i have this pedal,,,,it´s great,,,,,
boris
Do I "smell" another cloning, drawing, itching plan? Well...Boris?
You can count on me as usual bro.
- borislavgajic
- Opamp Operator
himister wrote:borislavgajic wrote:....wow....great........!!!....could you make trace side pictures like if you put PCB on scanner?...it is a lot easyer to clone pcb in that waynoise31 wrote:yeah..i have this pedal,,,,it´s great,,,,,
boris
you have my respect Mick.......I wanted to do this one, and atack delay.....thanks
boris
- borislavgajic
- Opamp Operator
how soon?
boris
- himister
Cheers for the photos but these are so small to do any tracing or pcb redraw.noise31 wrote:https://profile.imageshack.us/user/noise31/
Could you upload originals (BIG ones ) or reduce size just a little for upload.
Visibility is of utmost importance!!!
One good clean shoot of pcb from the center top of solder side.
If some traces couldn't be seen bellow the pots then shoot sideward to cover those traces also.
Sorry for bothering you noise32 but you will make Boris and me very happy, specially when pcb is done.
Thanks in advance.
- himister
Yeah. Thanks noise31...very much!
I don't know if you changed photos on image-shack since my last post but I guess maybe I couldn't see them in full size 'cause I wasn't logged there, if you didn't I apologize I didn't know for that option till now...my bad sorry.
Anyway pcb photo isn't complete and therefore we couldn't use it for redrawing.
Thanks for the effort.
- borislavgajic
- Opamp Operator
thanks noise31.....very much........but could I ask for two more photos....? please if you can make photo of complete PCB trace side(but not from an angle)....it should be like if you put it on scanner an make copy of it.........also component side(as narrow as possible) ....so we could use it as template in pcb drawing software
thanks again,and I hope we can help you with fuzz problem....?
boris
boris
- ckyvick
im not sure if this helps? its only the two knob version, but would it be possible to figure out the rest from this?
http://topopiccione.atspace.com/PJ19EHO ... lexer.html
i played the two knob in a store and found it to have less than unity output and its tracking was pretty jumpy.
- chicago_mike
Any diy info for the 5 knobber? I never knew this existed till 5 minutes ago.
Skyline FX 2013
- Scruffie
- Opamp Operator
Redrawn Schematic!
God this one was big, it'd be handy if anyone could cast an eye over it to check for any mistakes I might have made and haven't spotted
Source: - http://sites.google.com/site/electrocon ... actory.jpg
I left off the power supply for now... it's clear enough for anyone wanting to do a repair on the factory schematic and I doubt any DIYer is going to bother finding the correct one if they build this.
Hi Scruffie,could you please repost the redrawn schematic?When I click on the file the page is empty!Thanks!
KAPUTEPALLA
KAPUTEPALLA
