Univox - Superfuzz  [schematic]
Re: Univox - Superfuzz
Postby ShortScaleMike » 30 Oct 2008, 10:39
Solidhex wrote:With any Superfuzz build expect a delayed blast of hiss about a split second after you hit a note or chord. If you don't like it TOUGH!
--Brad
The ones I built didn't do this.
For this message the author ShortScaleMike has received thanks:
modman (18 Feb 2015, 22:49)
ShortScaleMike
Has thanked: 19 times
Have thanks: 92 times
Postby ShortScaleMike » 30 Oct 2008, 10:42
salocin wrote:To those of you who have built the superfuzz- do you have much trouble with hum/noise? Just finished mine off, and there's a fair amount of hum, which i've never had much trouble with in previous builds. I did have to twist the legs of the base and collector round as I used 2SC828's but the layout was designed for 2N2222's. Could that have anything to do with it?
My layout is for 2SC828s
ShortScaleMike
Postby salocin » 30 Oct 2008, 22:49
ShortScaleMike wrote:My layout is for 2SC828s
I'll certainly be using your layout for the next build, hadn't seen it when I started on this one though which is why I used the Ulysses layout from the DIYstompboxes gallery.
edit: Which schematic is your layout based off?
salocin
Have thanks: 7 times
Postby ShortScaleMike » 31 Oct 2008, 16:57
The univox one that is floating around the web. The electronic layout isn't verified yet unfortunately, the paper one I made this layout from was though.
ShortScaleMike
Postby Solidhex » 10 Nov 2008, 04:08
--Brad
I've built around 13 clones and have played through 3 Orange/Blue Superfuzzes and probably around 6 different rebranded (companion, shinei, jax, Crown, etc) Superfuzz circuit equipped fuzz/wahs through all sorts of different amp/guitar combos. The weird gate hiss thing is always there to some degree from my experience with the circuit. Adjusting the trimpot will get a minimum amount of hiss when the octave is well balanced but after hitting a chord I always hear the characteristic Superfuzz hiss...
--Brad
Solidhex
Has thanked: 10 times
Have thanks: 18 times
Postby salocin » 10 Nov 2008, 04:10
Cheers for the confirmation.
How about the hum? Is this typical of them as well, or is this possibility related to my build?
salocin
Postby Solidhex » 12 Nov 2008, 05:31
salocin wrote:Cheers for the confirmation.
Yo
If you're getting a constant hum its most likely your build. I read up on the usual debugging processes. If you're runnning a wall wart try it with a battery.
--Brad
Solidhex
Postby Kinki fuzz » 12 Nov 2008, 13:40
Don't forget this is called SUPERfuzz, so some hiss is needed!, :lol: if not, this would be called, fuzz'whatever', but not 'super'. Make nastiness part of your live, guys!! :P
Kinki fuzz
Has thanked: 18 times
Have thanks: 2 times
Postby Alex Frias » 13 Nov 2008, 17:00
Interesting point... but I think nastyness is present in sufficient doses in my life and in my pedals!
I have a Giannini (Braziliam Company) Superfuzz from 70's and even the layout was copied from the original.
It sounds cool and have a small portion of hum and hiss, they are there but not as an anoying factor.
Alex Frias
Have thanks: 14 times
Postby graemey » 11 Dec 2008, 23:28
ShortScaleMike wrote:I made designed and built a stripboard layout for this. the original layout is verified (it was a paper design), unfortunately this electronic version isn't as yet.
Here is the one I built:
Tones are footswitchable with a dual colour LED
Im putting this together as we speak...
Shouldn't one side of R3 reach up to hole h3 so it connects to Q1?
Also, isn't that a cut under R9 making 21 cuts in total?
Just thought I'd ask to avoid any mistakes! :?
graemey
Postby ShortScaleMike » 14 Dec 2008, 13:37
Looks like you're right on both counts there! Sorry about that, like I said my original hand drawn version is verified but this is not, I'll make those fixes shortly
ShortScaleMike
Postby graemey » 14 Dec 2008, 22:26
ShortScaleMike wrote:Looks like you're right on both counts there! Sorry about that, like I said my original hand drawn version is verified but this is not, I'll make those fixes shortly
Cool!
I got my circuit finished and it sounds brilliant!
I tried germanium diodes and then swapped them for LEDs. Both sounded great so I might rig-up a footswitch to change between them both.
Think I will get a video of this one up on Youtube soon. Let you know if I do...
Thanks for the layout! :applause:
graemey
Postby ShortScaleMike » 18 Dec 2008, 12:53
Cool!
Thank you for correcting it and thus making it verified (when I make the changes to it, it's on my home PC I try not to turn on since I'm in front of a computer all day. I'm glad you've got it working, it truly is a great design.
ShortScaleMike
Postby drmathprog » 18 Dec 2008, 14:31
Personally, except for the fact that it's AC powered instead of DC, I've always preferred the Univox Unifuzz to the Superfuzz. It's more versatile and useful.
drmathprog
Postby HEAD » 18 Dec 2008, 19:15
--Brad
--Brad
my first post here so far. Even though it is just a little off topic: Brad, you're not happen to be the bass player of a famous rock band, that forced me with their special fuzz sound to build a SuperFuzz too? :lol:
Thx!
Regards!
Helge
HEAD
Has thanked: 25 times
Have thanks: 43 times
Postby ShortScaleMike » 20 Dec 2008, 16:40
Thanks for teh corrections Graeme, this is now a verfied layout:
For this message the author ShortScaleMike has received thanks: 2
modman (19 Dec 2014, 16:45), tabbycat (03 Jul 2011, 05:26)
ShortScaleMike
Postby Fuzzer » 21 Dec 2008, 01:25
Fu Manchu, yeeeahhhhh. :thumbsup
For this message the author Fuzzer has received thanks:
hellbillydeluxe (29 Apr 2019, 10:50)
Fuzzer
Have thanks: 20 times
Postby graemey » 27 Jan 2009, 19:59
http://uk.youtube.com/watch?v=BPBn1VK8C ... annel_page
Finally got round to posting a youtube video of my Superfuzz.
Big thanks to Shortscalemike for the vero layout and, as you may see, I pinched the 'Starve' control idea also. :applause:
I used 2N3904 trannys in mine.
Check the link above. Fuzzchaos!
For this message the author graemey has received thanks:
graemey
Postby Sickle » 27 Jan 2009, 20:03
Slamming job, graemey!
Sickle
Postby ShortScaleMike » 28 Jan 2009, 16:33
graemey wrote:http://uk.youtube.com/watch?v=BPBn1VK8C-M&feature=channel_page
Wicked. Great job mate, I've watched a bunch of your videos before (you have some very nice gear indeed).
ShortScaleMike
Users browsing this forum: DiscoVlad and 10 guests
