MXR Equalizer Schematics
Moderators: RnFR, moderators
  • Advertisement
Postby george giblet » 06 Jan 2009, 05:59
I've been sorting through some of my stuff over the holidays and you might be interested in these:
MXR 6-band EQ:
MXR 10-band EQ:
Here's the location of the missing parts which can be updated from any new gut shots:
For this message the author george giblet has received thanks: 4
Dirk_Hendrik (29 Jan 2011, 20:56), IvIark (03 Feb 2011, 17:54), jimbob_400 (13 Jul 2011, 11:14), sinner (30 Jan 2011, 11:34)
george giblet
Have thanks: 4 times
Re: MXR Equalizer Schematics
Postby RnFR » 06 Jan 2009, 18:18
thanks george!
Has thanked: 137 times
Have thanks: 157 times
Postby fosnal1950 » 06 Jan 2009, 19:03
Is there anyone who knows if there is a pcb available for the 6 or 10 band ?
I'm not very good at designing it for so many opamps.
Alf
fosnal1950
Have thanks: 2 times
Postby Dirk_Hendrik » 06 Jan 2009, 21:57
As said before, thanks George.
Make those tapers linear. It's a linear cut boost app ;) (A "w" taper like in the TS tone control would be even nicer...)
Yup! All planes still in the sky and doing fine up there!
Has thanked: 161 times
Have thanks: 651 times
Postby fosnal1950 » 09 Jan 2009, 12:30
I have found a pcb and layout for the GE-7 but it's in pdf.
I can't show it here. Tried to convert it to jpg but all these so called free programmes add letters behind the converted file.
If anyone needs it mail me .
Alf
fosnal1950
Postby fosnal1950 » 09 Jan 2009, 16:14
Here you go : the site where I discovered it .
http://web.tiscali.it/boxsmt2clone2005/_web_boss_ge7/boss_ge7.htm
Alf
fosnal1950
Postby lolbou » 11 Jan 2009, 20:56
Hey,
I've been through this site already, but could not find the very linear faders that fit the PCB... Course I can modify them with an appropriate software, but does anyone know where to find these Boss style ones?
A bit off-topic maybe? Sorry about that... :|
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
lolbou
FSB Moderator
Has thanked: 234 times
Have thanks: 153 times
Postby nzino » 04 Feb 2009, 01:08
Hi
I need schematics of MXR 6 band EQ with footswitch (the latest one, black colured) to repair. Some one can help me??
Thanks.
nzino
Postby mecmast » 20 Jun 2009, 17:30
any layout/pcbs plz?
mecmast
Postby Rocket Roll » 08 Sep 2009, 23:34
MXR 10-band EQ master volume mod:
Rocket Roll
Postby shotgunn » 25 Nov 2010, 02:04
Better late than never... I just found this site. I have the PCB layout for the MXR-109.
For this message the author shotgunn has received thanks:
pmac7565 (05 Nov 2012, 23:49)
shotgunn
Postby mcraveri » 03 Dec 2010, 20:01
Hallo,
Does anyone have a layout with tracks?
Tanks
mcraveri
Postby Lonkero » 04 Dec 2010, 02:42
Why some freq gain stages use 1458 and some that TL op-amp?
Lonkero
Postby HTH » 28 Dec 2010, 15:15
Lonkero wrote:Why some freq gain stages use 1458 and some that TL op-amp?
noise specs?
HTH
Postby O.B.Y » 29 Jan 2011, 20:53
does it verified?
O.B.Y
Postby Dirk_Hendrik » 29 Jan 2011, 20:57
No.
factory schems never do it verified.
Postby O.B.Y » 06 Feb 2011, 02:57
Dirk_Hendrik wrote:No.
so... have you built it?
O.B.Y
Postby Dirk_Hendrik » 06 Feb 2011, 19:59
Nope. I undid unverified it! Much less harder funstuff :horsey:
Postby O.B.Y » 18 Mar 2011, 14:42
Dirk_Hendrik wrote:Nope. I undid unverified it! Much less harder funstuff :horsey:
ya i cant find for the potentiometer with lower value..
so can u give me for the solution??
O.B.Y
Postby Fix_Metal » 29 Mar 2011, 23:16
K guys, I'm in a good mood on today.
On today I just brought to new life the M108, including an LT1054 inside, a footswitch, MTB2, tantalium caps changed over film caps. In the past I tried to mod it adding volume and gain slide pots. I drilled the box and so on. Since I had cracked the original writings, I stripped the box and painted it new. Same blue but I have no clues on how to restore the original font/white writings.
Anyway, check this out. This is the original schematic for the M108 Blue Box Version. Mine had (once) written MXR Graphic Equalizer, as you can see in my pic.
I've drawn and uploaded this schematic on diyitalia.eu, which is an Italian forum (I'm Italian), about a year ago. Never thought I'd publish it in here, that's why there is a "Permission refused blabla" in the pic.
Consider this to be my thanks to this great forum, where I found many detailed and ready-to-go projects.
The SN is: 804116
Enjoy :D
p.s. slide pots seems to be 20K linear. I measured'em one by one and the readings showed values from 14KOhm to 22KOhm.
For this message the author Fix_Metal has received thanks:
karul (14 Mar 2013, 15:36)
Fix_Metal
Have thanks: 10 times
Next
Users browsing this forum: tassosmavr and 9 guests
