MXR Equalizer Schematics
Re: MXR Equalizer Schematics
Postby Froebel » 02 May 2012, 14:26
Can I fit the linear slide resistors externally with wires
Froebel
Postby Froebel » 03 May 2012, 10:39
Hey see if this helps
I am trying to make a PCB layout with Eagle Layout Editor
For this message the author Froebel has received thanks:
kaycee (07 May 2012, 20:20)
Froebel
Postby Govmnt_Lacky » 03 May 2012, 13:46
Not to poop on anyone's parade but...
It clearly stated on the MXR schematic for the 6-band that ALL of the slider pots are:
"CTS spld taper 15K. 10% resistance at 25% rotation. 90% resistance at 75% rotation."
I see most of the diagrams that people are generating as having 50K sliders :?:
After looking at several taper curves, it appears that this taper reflects an EQ (W) taper as pointed out earlier in this thread.
Govmnt_Lacky
Have thanks: 42 times
Postby Fix_Metal » 05 Nov 2012, 18:37
Govmnt_Lacky wrote:Not to poop on anyone's parade but...
6b is different than the 10b
Fix_Metal
Have thanks: 13 times
Postby Dirk_Hendrik » 05 Nov 2012, 18:51
Although I agree qith you that the combination of a reverse los and a log taper over the full travel, making a w-taper indeed, gives a superior response but functionally the value doesn't make a difference at all. Take 20k linears and the circuit still behaves like an EQ with the same min-max cut boost values. Make em 100k linear and it still behaves like an EQ with the same min-max cut boost values
Has thanked: 250 times
Have thanks: 995 times
Postby jimosity » 14 Mar 2013, 13:01
On the ten band, is it possible to bypass the AC input and have it run right off of DC?
Does that mean it needs 15vDC or can it be modded to run on 9VDC (maybe with a charge pump and bipolar supply?)?
jimosity
Have thanks: 5 times
Postby lead2203 » 14 Mar 2013, 14:05
I have a bunch of these 15K sliders NOS from MXR if anyone need them.
lead2203
Have thanks: 9 times
Postby Fix_Metal » 16 Nov 2013, 21:40
jimosity wrote:On the ten band, is it possible to bypass the AC input and have it run right off of DC?
You need ±15VDC to have the same original rails.
Fix_Metal
Previous
