Sola Sound - Supa Tonebender: four transistor version
Hi
I have been lurking around this forum for too long without contributing. Thought I would post gutshots and part refs for my mid 70s tonebender. I haven't seen any schems of this version using 4 x BC184 transistors so hopefully it is of use to someone. Much thicker 'brickwall' style fuzz than the 3 transistor version, rakes of volume also.
All metal box caps say '250/u1' (u is backwards like mf ), there is one metal box near the bottom left that is smaller and this says '400/10n' on it.
All cylindrical foil caps say '470pf'. The one Mylar green cap says '472'. The large electrolytic is 22uf. Volume and gain pots at the top are 100kB, and tone (Bottom middle) says 100KA.
All Transistors are BC184.
EDIT: Diodes are unmarked, but look like generic silicon 1418s etc
Trace side:
Enjoy!
JJ Gabor
Trace side:
Enjoy!
JJ Gabor
- analogguru
Thanks for the pictures !!!
First time that I see the track side....
It seems that it matches with this work:
http://eu11.stripper.jp/pulcino/blog/ar ... ender.html
scroll down for schematic.
Cool, there is already a schem. I was hoping that I could clone this and sell it on as they sell for fairly stupid prices.
I posted gutshots of an efffector 13 TBD in the boutique section, but i just found the disaster fuzz shots so it might be redundant.
I have the following that i could shoot if anyone was interested:
EH Microsynth
Moogerfooger lowpass filter, phasor and Ring mod (don't know how easy it would be to get at the trace side)
EH Microsynth
- alteredsounds
Just cracked open 6 Colorsound TB's to have a transistor count, out of the 6, all fairly different looking, one has 4 transistors:
- soulsonic
Oh wow, it's a Big Muff!
- PurplePeopleEater
<minus one set of diodes> shhhh.....soulsonic wrote:Oh wow, it's a Big Muff!
- Alex Frias
A Not-So-Big Muff?
- alteredsounds
Sure is basically a muff, wonder why most are 3 transistor, the variance between parts used, not especially values is huge, whatever was in the parts bins that week i would guess.
- PurplePeopleEater
Most Jumbo Tonebenders are a Big Muff minus the final recovery stage. That's why 3 transistors instead of 4.alteredsounds wrote:wonder why most are 3 transistor
- alteredsounds
Makes sense now u say that, not really a fan of muff circuits so not looked at them b4PurplePeopleEater wrote:Most Jumbo Tonebenders are a Big Muff minus the final recovery stage. That's why 3 transistors instead of 4.alteredsounds wrote:wonder why most are 3 transistor
- mattpas
The board doesn't match the schematic on that siteanalogguru wrote:Thanks for the pictures !!!
- mattpas
some resistor values are differentpakalolo wrote:If you look at the first pics posted, R8 (from Q2 base to ground) is missing.
It is present in alteredsounds version though.
Otherwise, I don't see any differences between the pics and the schem.
this comes from not having clipping diodes on the first gain stage (Q2).... when u remove these diodes there is obviously no clipping and it really ads to the lowend of the tone.... some like to put a 1m pot wired to the diodes on Q2 of muffs to control the amount of clipping to get anything from the Supa to a Muff tonelohstah wrote:yeah, that´s really peculiar and i love it with bass guitar.It almost sounds like it has clean signal mixed in
and works perfectly ok with active basses.
cheers,
lohstah
- Cub
That's what also makes it a fantastic Fuzz for humbuckers. Rick "Frequency Central" Holt put the 1M pot Jarrod is talking about on his perf layout. (click here for the thread about it)SGJarrod wrote:this comes from not having clipping diodes on the first gain stage (Q2).... some like to put a 1m pot wired to the diodes on Q2 of muffs to control the amount of clipping to get anything from the Supa to a Muff tonelohstah wrote:yeah, that´s really peculiar and i love it with bass guitar.It almost sounds like it has clean signal mixed in
It's on my to do list to build a Steve Hackett sounding Fuzz pedal that's capable of a little something more if I want it to.
Hi guys, I'm making a replica of Supa fuzz, but Steve Hackett edition, anyone know the values that change or type of transistors used, or is it just the original with a sticker?
Thanks guys!
Thanks guys!
