Myths, Legends and the Mojo of the Dallas Rangemaster
- Greenmachine
- my favorite amplifier: Fender Blackface Deluxe Reverb
- Completed builds: Electra Distortion
Roger Mayer Octavia
Klon Centaur (Bajaman/Soulsonic)
DOD 440 Envelope Filter
MXR Phase 90
DOD FET Preamp
Dallas Arbiter Fuzz Face
Soulsonic Hunny Bunny Overdrive
BYOC Analog Delay
Craig Anderton Headphone Amp
Anderton Mini Amp
Bajaman Real Tube Overdrive
Fender Deluxe 5E3 with Tone Stack Mod.
Fender Princeton 5F2-a
Keen Neovibe
Aquapuss Delay
Anderton AMS-100 Guitar Synth (abandoned)
DOD 280 Compressor
Weird Sound Generator
Beavis Audio Noisy Cricket
80's Rat
ROG Thor
Big Muff
Green Ringer
Shin-Ei Fuzz
MXR Dynacomp
COT50
Really Cheap Compressor - Location: Jersey City, NJ
- Has thanked: 87 times
- Been thanked: 17 times
- Contact:
how dose the Beano boost let you switch 3 input caps with a SPST toggle switch?
I can even work out how to do it with a ON ON ON DPDT toggle switch?
Anyone got wiring diagrams for multiple inputs using toggles, not rotary switches?
- Scruffie
- Opamp Operator
It'll be an On/Off/On SPDT not SPST.carboncomp wrote:how dose the Beano boost let you switch 3 input caps with a SPST toggle switch?
And with a On/Off/On DPDT... stick the smallest value cap in the center and connect it's two lugs to where the input caps went, then stick two larger caps on either side of the switch and they'll parallel with the middle to give you two new larger values.
SPDT is the same but you connect 3 legs of the caps together.
- JVanDe7
- Completed builds: DAM Red Rooster clone, Zvex Octane 3 clone, Zvex Fuzz Factory clone, Maestro MFZ-1 clone, Fulltone Soul Bender clone, Fulltone 69 clone, Green Russian Muff clone, Dallas Rangemaster clone, Mosrite Fuzzrite clone, EA Tremolo, VOX Clyde McCoy wah, Jordan Bosstone clone, Analogman Sun Face clone...
- Has thanked: 21 times
- Been thanked: 10 times
Anyone know of a verified NPN vero layout for a straight-up Rangemaster clone?
“Walk tall, kick ass, learn to speak Arabic, love music and never forget you come from a long line of truth seekers, lovers and warriors.”
― Hunter S. Thompson
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
JVanDe7 wrote:Anyone know of a verified NPN vero layout for a straight-up Rangemaster clone?
0.15" pitch? 0,1" pitch?
- JVanDe7
0.1" pitch is what I have at home so that would be ideal.
I'm looking to create (recreate?) a Rangemaster variation...
viewtopic.php?f=7&t=17725
So inplace of the input capacitor I want to have a 6-way rotary switch, to choose from 6 different values from .0047uF up to .15uF
But that doesn't need to be on-board. I can create a separate small board for the input caps or just solder them to the switch (could get messy).
I just want a nice clean vero starting point that I can use with the CV7112 NPN Ge tranny I have at home. A 5K bias trimpot on the board (instead of 3k9) would be great too if possible.
- sinner
JVanDe7 wrote:0.1" pitch is what I have at home so that would be ideal.
Awesome then... I've started PNP 0,15" project meanwhile
give me 15 minutes
- sinner
- JVanDe7
Right on man. That was fast!
I don't mean to be rude but I noticed some variations...
http://www.geofex.com/article_folders/r ... tboost.pdf
You like the 25uF electrolytic caps instead of 50uF?
Also noticed the 39K instead of 3K9?
- sinner
Most of the picts of RM's I've seen shows 25uF for both locations, that's why I did it that way, 39k was my error, thanks for spotting that
Corrected layout added + that big one I did earlier - with 50uF for filtering
- Dr Tony Balls
Here's the layouts I use for my Ballsmasters with 4-way selectable input caps. The input goes to the center of the rotary and then each leg of the rotary connects to the bottom side of one of the four caps on the left. The top layout is spaced for .1 inch and the bottom for .15. This is NPN and also laid out for mojo parts.
- JVanDe7
That's very generous of you man. Thanks!
Cool layout. If you could somehow rearrange the order of the wiring for the pot, you could even use a board-mount pot. Kind of convenient because then you don't have to worry about mounting the board somehow.
- beedotman
I have finished NPN RM with input cap blend recently on .015" pitch vero, here's gut shot.
Will post layout later during weekend. Maybe will rearrange it a bit, because it's not perfect - input wire going to electro cap is to close to ground rail and it cause short circuit... But without cap blend will work perfectly
- rm2.png (440.56 KiB) Viewed 2774 times
- beedotman
Doc - on smaller vero You have to place one more cut - now 47nF input cap is connected to power railDr Tony Balls wrote:Here's the layouts I use for my Ballsmasters with 4-way selectable input caps. The input goes to the center of the rotary and then each leg of the rotary connects to the bottom side of one of the four caps on the left. The top layout is spaced for .1 inch and the bottom for .15. This is NPN and also laid out for mojo parts.
cut under 10nf cap will do the job
- DrNomis
- Has thanked: 98 times
- Been thanked: 279 times
For anyone interested in hearing what a Rangemaster Treble Booster can do with an amp, just check out the first two Black Sabbath albums and listen to the tone Tony Iommi is getting, as he used a Rangemaster in the early days of Black Sabbath....
Note that he was using a Gibson SG guitar....
- Dr Tony Balls
beedotman wrote:Doc - on smaller vero You have to place one more cut - now 47nF input cap is connected to power railDr Tony Balls wrote:Here's the layouts I use for my Ballsmasters with 4-way selectable input caps. The input goes to the center of the rotary and then each leg of the rotary connects to the bottom side of one of the four caps on the left. The top layout is spaced for .1 inch and the bottom for .15. This is NPN and also laid out for mojo parts.
OH SHIT....you're right, and i did this on paper in my printed version. forgot to change it on the digital version.
- JVanDe7
Any advice as far as which rotary switch to use? I understand if you'd rather not say. Thanks either way.
