Top Gear - Sound Rotator
borislavgajic
Has thanked: 131 times
Been thanked: 281 times
Post by borislavgajic »
not very clear pictures,but...... :wink:
MoreCowbell
Been thanked: 15 times
Post by MoreCowbell »
I dig the old stripboard layout. I wish the pics were more clear, but I'm sure it was a PITA to get pictures of a rare old unit like that in the first place....
Thanks... :D
Bernardduur
Has thanked: 94 times
Been thanked: 737 times
Post by Bernardduur »
Wow..... that looks really nice...... what does it do? I "guess" chorus and tremolo????
Some better pics here although they won't add much :)
borislavgajic
it has 4 ldr's ...placed around light bulb........so it is IMHO transistor vibrato..or phaser... :D
it sounded very dull and muddy ...
I had it for one day only ..long enaugh to take photos....
:horsey:
http://www.harpamps.com/schematics/univibe.pdf
DiscoFreq
Been thanked: 27 times
Post by DiscoFreq »
EffectsDatabase: http://www.effectsdatabase.com
22000 pedals, 4000 brands, 350 brand interviews
NAMM 2016: http://fxdb.org/namm
borislavgajic
I could get to this pedal again........so is somebody interested to trace this .....and to help me fixing it......sound was not sharp (clear)........bad capacitors??? something else......
if there is any interest,I will get to it :thumbsup
boris
Professor SourTone
Been thanked: 58 times
Post by Professor SourTone »
borislavgajic wrote:I could get to this pedal again........so is somebody interested to trace this .....and to help me fixing it......sound was not sharp (clear)........bad capacitors??? something else......
boris
Boris - its possible I now own this pedal, as it came to me from Serbia - is there a schematic anywhere?
Professor SourTone
It is now being looked at - lots of things wrong with it, bad photocell, oscillator, transformer buzz. Wet still very dull and wet/dry not "summing", whatever that means. It will sound very different when fixed, I suspect. H
Professor SourTone
Professor SourTone
Herewith circuit diagram + post-fix gutshots by Dan Coggins of Dinosaural, although he stresses that without rebuilding it, the oscillator section may not be 100% correct.
It had a dead RPY58A photoresistor (replaced with ORP12, similar functionally), oscillator needed tuning, lube trimpots, fix buzzing transformer, dry joint on level pot.
One mod, 22k "straight blend" mod resistor across bypass switch to brighten it up. Buffer recommended as input impedance very low.
https://flic.kr/s/aHsmi83jTG
Its not arrived home yet, but the IG link in my previous post suggest its a changed beast!
Zokk
Has thanked: 211 times
Been thanked: 68 times
Post by Zokk »
Hi, please could you post the pictures on another media: both links don't work for me.
Thanks.
Scruffie
Has thanked: 28 times
Been thanked: 170 times
Post by Scruffie »
And here I was thinking it was just going to turn out to be another UniVibe, that actually looks interesting, seems it's just a transistor based version of the later 'Rotator'. I'll be interested to hear how it sounds, I can't quite picture it.
Nocentelli
Has thanked: 1155 times
Been thanked: 954 times
Post by Nocentelli »
Scruffie wrote:interested to hear how it sounds, I can't quite picture it.
I'm also intrigued. If you can't see the flickr schematic, it's like four colorsound inductor-less twin-T wah circuits in parallel but all tuned to different bands, and all modulated by a (PSO?) LFO. I am going to type thing out with a LED instead of the lamp.
Professor SourTone
Zokk wrote:Hi, please could you post the pictures on another media: both links don't work for me.
Thanks.
I will have a go - what’s the recommended way nowadays, photobucket is hopeless now.
Professor SourTone
This from Dan - “A view of the audio filter board. There are four summed (parallel) band-pass filters using Wien-bridge networks, whose frequency bands are roughly an octave apart and each are adjusted to be on the threshold of resonance using individual trimpots. The four of these single transistor stages added together provides four deep notches that sweep up and down together and carve out the input signal. The additional resistor provides more straight signal bandwidth for these to cancel agains @Level=8.”
Zokk
Post by Zokk »
Professor SourTone wrote: I will have a go - what’s the recommended way nowadays, photobucket is hopeless now.
Thanks, you can upload the pictures directly on the forum, check the tab below when you write a message :"upload attachment".
Professor SourTone
Sorry delay
EddieTavares
my favorite amplifier: marshall
Been thanked: 26 times
Post by EddieTavares »
How does it sound?
