I've never even even heard of this. There's a component side shot in the auction.
Reading between the lines it doesn't sound so great so maybe that's why they didn't make so many. But I think 79 must have been near the end for Colorsound anyway?
I'm pretty sure that's been re-listed a few times: I recognise it because the same guy has also re-listed this weird Orange/Gary Hurst Tremelo prototype a couple of times:
Maybe there are some obsessive collectors out there who will pay that much for these oddities, but it seems not that many.
modman wrote: ↑Let's hope it's not a hit, because soldering up the same pedal everyday, is a sad life. It's that same ole devilish double bind again...
rare birds indeed. i'd like to save a couple pics to the forum for posterity, but i can't figure out how to save them with ebay's new picture setup.
RnFR wrote:rare birds indeed. i'd like to save a couple pics to the forum for posterity, but i can't figure out how to save them with ebay's new picture setup.
If you're using Firefox, click "enlarge", right-click outside the image area but inside the pop-up window, select "view page info", go to the MEDIA tab, and select/save the pic.
You need an older browser.... I am using IE 5.5 and don´t have any problems saving pictures.
Dirk_Hendrik wrote:SOURCE FOR SAD512D PLEASE, PREFERABLY THE ONES NOT MADE OF INFANT PYGMEE FORESKIN LEATHER OR THE CHEAPER VARIANT MADE OF UNOBTANIUM!!!
No individuals please. 1-Source is a business-to-business distributor.
Minimum order $250.
I have the same problem with SAD1024 chips, several broken pedals which probably need a new chip: EH Full Double Tracking, EH Slapback Echo, Monacor (Univox) Flanger/Delay,...
DiscoFreq wrote:No individuals please. 1-Source is a business-to-business distributor.
Minimum order $250.
Someone makes an adaptor PCB to allow a MN3007 to replace the SAD1024. My Google-fu is weak today, so you'll have to look for it yourself!
Minimum order $250.
Regarding sound... it's nice enough for what it is but the wet level is quite low, max delay clock setting was 3.8kHz (I think, going from memory a bit) so about 135mS max delay and it is murky.
The 2 trims next to the SADs are clock cancel and the 2 further away are the bias, the 741 is the voltage regulation circuit and the TL061 is the clock.
