B&M Sola Sound - Fuzz Unit  [schematic]
Postby SPeter » 19 Aug 2009, 01:13
Hi All,
Nice guts and ridiculous price! Identical to Vox MKIII ToneBender:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0464153930
For this message the author SPeter has received thanks:
Desdog (18 Mar 2015, 19:44)
SPeter
Have thanks: 76 times
Re: VINTAGE B&M SOLA SOUND FUZZ GUITAR PEDAL EFFECT
Postby SPeter » 19 Aug 2009, 01:37
SPeter
Postby Electric Warrior » 19 Aug 2009, 01:47
that's not true. the Barnes and Mullins Fuzz is nearly identical to the Jumbo Tonebender. The MKIII is a different breed.
there's a whole lot of gut shots to be found at the D*A*M forum...
Electric Warrior
Has thanked: 20 times
Have thanks: 87 times
Postby Greg » 19 Aug 2009, 02:56
Electric Warrior wrote:that's not true. the Barnes and Mullins Fuzz is nearly identical to the Jumbo Tonebender.
Which is pretty much a Big Muff.
Yes the MKIII is very different.
Greg
Has thanked: 77 times
Have thanks: 195 times
Re: B&M Sola Sound - Fuzz Unit
Postby rs » 19 Aug 2009, 03:15
I have a colorsound supa-wah-fuzz-swell, and the fuzz board is identical, same layout.
rs
Has thanked: 99 times
Have thanks: 7 times
Postby Electric Warrior » 19 Aug 2009, 07:19
There's two or three different layouts for the jumbo circuit with vertical controls.
some have slightly different resistor values (39k instead of 33k and 10 instead of 8k2) and/or component types (ceramic caps vs. styroflex). What I believe to be the earlier units have tropical fish caps instead of the greenies.
The values of the ceramic/styro caps may vary as well, but it's hard to see in the pictures I found. I've seen styroflex caps with a 500pf color code. Others have the number 220 printed onto them (or is this the voltage rating?). The ceramics in the ebay pics are 470pF. Does anybody have some more data?
And I'm not quite sure about the small cap at lug 1 of the tone pot. is it supposed to be 0.003µF or 0.004µF?
Electric Warrior
Postby sonicvi » 19 Aug 2009, 15:32
Electric Warrior wrote:There's two or three different layouts for the jumbo circuit with vertical controls.
It's usually .0039uF and that's what the original schematic calls for. Sola Sound called the B&M circuit "Fuzz A" and it is identical to the Jumbo with the exception of a 220K resistor at the output. I'm not sure what the purpose of that resistor is as it reduces the volume quite a bit. The pots are usually either all log taper or log for the volume and sustain and linear for the tone. Everything else about this circuit is pretty much evident from the photos and the "Fuzz A/Jumbo Tone Bender" schematic on the web. I think everybody pretty much knows by now the Jumbo is the same circuit as the Big Muff with first pair of clipping diodes and post tone gain stage removed. Doesn't sound like much but they're pretty significant differences soundwise.
sonicvi
Have thanks: 12 times
Postby Electric Warrior » 19 Aug 2009, 15:41
right, it says "Fuzz A" on the schematic and on the trace side of the circuit board.
thanks a lot for your help!
this is where the B&M porn is: http://dam.10.forumer.com/viewtopic.php ... es+mullins
Electric Warrior
Postby peps1 » 01 Sep 2010, 23:28
Anyone come across a PCB layout for the B&M Fuzz Unit/3rd party Jumbo Tonebenders? :hmmm:
peps1
Have thanks: 56 times
Postby celadine » 02 Sep 2010, 04:15
http://www.generalguitargadgets.com/
all kinds of goodies there; look under "projects".
celadine
Has thanked: 16 times
Have thanks: 16 times
Postby peps1 » 04 Sep 2010, 01:38
Going the DIY route :D
Anyone happen to know the make and model of POTs, so I can get the pin spacing to scale the board?
For this message the author peps1 has received thanks:
Belanger88 (30 Oct 2016, 00:04)
peps1
Postby Scruffie » 04 Sep 2010, 01:50
peps1 wrote:Going the DIY route :D
Aren't they the same Pots that EHX used? I think 24mm Pots have a fairly standardized pin spacing unless you use those other EHX ones with more spread out legs.
Scruffie
Has thanked: 28 times
Have thanks: 144 times
Postby Electric Warrior » 04 Sep 2010, 01:53
They're Radiohms. No idea what happened with Radiohm, their products were available until recently. Replacements are available from Omeg amongst others..
Electric Warrior
Postby sonicvi » 04 Sep 2010, 09:05
I used the right angle 16mm pots from Small bear in my clones and they just about fit the original spacing. I couldn't find the original type pots anywhere.
sonicvi
Postby Electric Warrior » 04 Sep 2010, 16:03
Tyco/Citec makes Radiohm replacements as well..
Electric Warrior
Postby peps1 » 04 Sep 2010, 16:19
mmmmmm......still finding variants in the pin spacing for the Tyco/Citec/Omeg Radiohm replacements (you got a model number for the 24mm Radiohm color sound used in this bad boy?)
Would be nice to drill the pot pads large enough to allow use of original, and 16mm Alpha pots :hmmm:
peps1
Postby SPeter » 04 Sep 2010, 21:54
Luckily I have some of these old pots!I realy love them! Pins(lugs) are 1mm wide and distance from lug 1 to lug 3 (center to center) is 10 mm!
:D
SPeter
Postby SPeter » 04 Sep 2010, 22:29
Scaled to the above mentioned distance(10 mm)!
Enjoy!
:D
SPeter
Postby Electric Warrior » 05 Sep 2010, 01:14
peps1 wrote:mmmmmm......still finding variants in the pin spacing for the Tyco/Citec/Omeg Radiohm replacements (you got a model number for the 24mm Radiohm color sound used in this bad boy?)
I believe these are the right ones:
The Omegs are identical:
So are the Citecs:
For this message the author Electric Warrior has received thanks:
Belanger88 (30 Oct 2016, 00:05)
Electric Warrior
Postby peps1 » 05 Sep 2010, 01:42
peps1 wrote:I believe these are the right ones:
Thanks Electric Warrior, with a 10mm pitch that fits in with SPeter...... sincerely thank you for taking the time to help! :D
Etched a test board, and found a couple of minor things i need to change to get it BANG ON authentic........ but will post with amended files tomorrow :D
Now the fun part of working out the component layout
here is the photo im working from, incase anyone is handy with resister color codes and wants to help :wink:
peps1
Next
Users browsing this forum: roberttomasz and 4 guests
