Craig Anderton ultra fuzz 1975 sch
- Dr Tony Balls
I have a much more recent version of the book, and the schematic of the ultra fuzz is QUITE different than that. Make of that what you will.
Also, what are you drawing with? Visio or Omnigraffle or something? Into it.
I used a free download called expressSCH which is included with expressPCB. Then I copied it into paint and and made my own ground and battery symbols because I don't like the ones that come with the program. ExpressPCB provides free design software ( not trial ) so you can design a PCB and they will manufacture it for you. Looking at there finished boards they look very similar to the ones GGG sell but that is just speculating. I know this book has been revised many many times over 34 years and I'm sure his projects have been refined. I'd be interested to see what the later version looks like. Is it also powered by 2 9v batteries? He also calls this a "Noiseless Fuzz" because it has a natural GATE effect.
The polarity of B2 looks right : the negative side towards the negative supply of the opamp.
This circuit rerminds me a lot of the opamp muff fuzz made by EH, except that there are no diodes in the feedback loop of the second opamp. This second opamp is at full open loop gain... creating the gating effect !
Patafix... so sticky
- RnFR
you could use a max1044 for getting a bipolar supply out of a single battery. it might simplify things... or not.
looking forward to hearing how this pedal turns out, i've always been intrigued by it.
Question. My first attempt at this circuit failed but I built it with 2 741 op amps rather than 1 dual. I havent looked closely at it yet to determin where I went wrong. I have dual op amps but they are bi-fet and I wasn't sure they would work properly. The only other substitution I made was a 100p rather than 150p between pins 2 and 3 of opamp 1. I greatly appreciate any advise. If it is to get the right op amp and use the layout in the book what should I use in place of a 5558? sorry for my newby ignorance.
- RnFR
you did use two batteries, right?
Well I finally got back to this and got it finished sounds pretty good and I'd like to put a sound clip on but not sure how to go about it. My recording setup records to wav files and when I convert them to mp3 they sound like crap. Whats the best way to record a sound clip and put it on the internet? Is there something like photobucket for music? preferably for wav files.
- RnFR
i've seen many people use soundclick. not sure about .wav files though.
- sinner
- Has thanked: 1031 times
- Been thanked: 909 times
For fuck sake! I cant understand this thing
I'm doing layouts for this and I can't comprehend that powering. It does uses two stereo jacks yeah? For input, and for output.
Input jack's middle (slave) lug is battery minus, tip is circuit input to switch, ring is circuit ground
Output slave is battery PLUS, tip output connection to switch, ring is what? V+? V- will short...
- sinner
Ok, now I see in Andersons book totally different project... Name's the same, but different IC, additional controls, much more parts...
