Pearl - F-605 (Analog Delay)  [schematic]
Re: Pearl - F-605 (Analog Delay)
Postby analogguru » 28 Jul 2008, 17:20
Dirk_Hendrik wrote:Sold or listed?
The rough average I've seen them go for is around 120.
sold - approx. two years ago or so.
Have thanks: 116 times
Postby analogguru » 28 Jul 2008, 17:39
BTW, on my unit from (autumn 1978) the 3k9 resistor at the input is actually 1k and the 2M2 from collector to base of the input stage is 3M3, transistors are 2SA 564A-R. Power supply transistor is 2SA 777-R.
Postby Dirk_Hendrik » 28 Jul 2008, 19:04
Including manual and box?
Has thanked: 255 times
Have thanks: 1033 times
Postby Bernardduur » 28 Jul 2008, 20:08
Thanks! I'll try the suggestions + some true bypass work :)
Sound is really nice btw! I find it to sound more like a tape echo then an analog delay (like my Pearl AD-08); it cuts lows on the delays so you really get that tape echo trebleness I like!!
Really surprised right now :D
Bernardduur
Has thanked: 87 times
Have thanks: 489 times
Postby DiscoFreq » 28 Jul 2008, 20:31
The prices vary a lot, I've seen them for around 100 but also 200. Usually they are sold cheap when I don't look at them the last day or when I didn't bid, grrrr :)
I think I'll have to buy me an electrical screwdriver, put the camera on a stand, put some white paper or sheet on the floor and have a big "gutshot day" so analogguru can reply to my posts without mentioning gutshots :p
EffectsDatabase: http://www.effectsdatabase.com
22000 pedals, 4000 brands, 350 brand interviews
NAMM 2016: http://fxdb.org/namm
DiscoFreq
Have thanks: 25 times
Postby Bernardduur » 29 Jul 2008, 10:57
Wow
That mod did the trick really well. Now the unit is silent and the only hum I hear is from my single coils.
Awesome!
Bernardduur
Postby fotoplastikon » 25 Jan 2009, 22:16
Hey,
I've bought this delay as a broken some time ago.
Previous owner made strange connections inside and it seems that some of wires are connected in wrong places.
Is there any chance to get detailed inside photos of this unit including wires connections?
Thank you in advance!:)
fotoplastikon
Postby lohstah » 12 Feb 2009, 15:44
i returned to this effect to solve my "last" mystery:
when i put the switch on "chorus" or "duplex" setting and choose shorter delay times, i get a noticeable amount of distortion. what gives ?
i get 13.5 V out of the zener/trannie arrangement.
searching for different settings for the bbd bias did not help, it is good as it is set...also the clock trim is ok.
in the delay setting, the sound is perfectly ok. :scratch:
btw, what does that third trimpot do (the 220k near the fet that goes to ground) ?
cheers,
lohstah
lohstah
Has thanked: 201 times
Have thanks: 97 times
Re:
Postby borislavgajic » 13 Feb 2009, 11:26
analogguru wrote:If you can wait.... I have one.... somewhere I even have the schematic tracing too. A nice delay with a special feedback feature, but sadly without a compander.
Dirk Hendrik may also have one ?
please, I would like to see schematic....if it is possible :block:
and is there version of MN3005 in small DIL8 package(like TL082).....or it have to be long BBD body(in one place they are selling them, but on picture there is normal DIL8 ic)???
thanks
boris
borislavgajic
Has thanked: 140 times
Have thanks: 252 times
Postby Dirk_Hendrik » 13 Feb 2009, 11:53
It was on page 2 of this thread. Unfortunately Bernardduur seems to have the nasty habit of taking things down..
Yo Rogier!
gooi dat schema weer es effe naar boveh wil je!
Postby lohstah » 13 Feb 2009, 15:42
it is one of the big mn3005 er´s, with the space in between the pins.
i still have that schematic saved, i don´t know if it was the last version; if it´s ok with bernarddur, i can put it up as an attachment.
cheers,
lohstah
lohstah
Postby borislavgajic » 14 Feb 2009, 08:42
lohstah wrote:it is one of the big mn3005 er´s, with the space in between the pins.
cheers,
lohstah
it would be great if yo attach it here!
thanks
boris
P.S. what is the best analog delay (MN3005) that I could build???
borislavgajic
Postby Bernardduur » 14 Feb 2009, 11:25
Dirk_Hendrik wrote:It was on page 2 of this thread. Unfortunately Bernardduur seems to have the nasty habit of taking things down..
Yo Rogier!
Woops, grote schoonmaak hier
(on a big cleaning spree; schematic will be up soon!)
Enjoy the schematic
Bernardduur
Postby Dirk_Hendrik » 14 Feb 2009, 11:50
Thanks!!!
Postby borislavgajic » 14 Feb 2009, 20:14
:thumbsup thank you very much
boris
p.s.
so what build is my next..this , or "aqua pussy"???......
borislavgajic
Postby lohstah » 15 Feb 2009, 16:36
apart from the happiness that the schematic is up again and the questions of what to build next, does anybody have an idea what´s causing the trouble with my pearl ? :wink:
cheers,
lohstah
lohstah
Postby lohstah » 20 Feb 2009, 20:31
update on my pearl woes: also the short delays are distorted. not only in the chorus settings, but also in the pure dealy setting.
so, what can cause distortion in short delays, the shorter, the more distorted, while long delays are perfectly ok ?
it´s not the mn3005, i tried another one and the trouble stays the same.
cheers,
lohstah
lohstah
Postby professor plum » 09 May 2010, 02:58
hey guys, i was just wondering if anyone knew the approximate delay time on this thing? thanks!
professor plum
Postby Dan N » 09 May 2010, 22:32
I would guess it's in the same neighborhood as other mn3005 based delays- 500 to 600ms of clean delay? Think DM-2 and AD-80 time amounts.
Dick joke has expired.
Dan N
Has thanked: 57 times
Have thanks: 19 times
Postby Scruffie » 09 May 2010, 22:42
Each MN3005 only delivers around 300ms of Delay (204.8ms according to the datasheet but that doens't mean it can't be pushed further) and as far as I can see this only has a single chip so that much.
Scruffie
Has thanked: 28 times
Have thanks: 141 times
Users browsing this forum: Electric Warrior and 9 guests
