Page 3 of 4
Re: Pearl - F-605 (Analog Delay)
PostPosted: 28 Jul 2008, 17:20
by analogguru
Dirk_Hendrik wrote:Sold or listed?
The rough average I've seen them go for is around 120.
sold - approx. two years ago or so.
PostPosted: 28 Jul 2008, 17:39
by analogguru
BTW, on my unit from (autumn 1978) the 3k9 resistor at the input is actually 1k and the 2M2 from collector to base of the input stage is 3M3, transistors are 2SA 564A-R. Power supply transistor is 2SA 777-R.
PostPosted: 28 Jul 2008, 19:04
by Dirk_Hendrik
Including manual and box?
PostPosted: 28 Jul 2008, 20:08
by Bernardduur
Thanks! I'll try the suggestions + some true bypass work :)
Sound is really nice btw! I find it to sound more like a tape echo then an analog delay (like my Pearl AD-08); it cuts lows on the delays so you really get that tape echo trebleness I like!!
Really surprised right now :D
PostPosted: 28 Jul 2008, 20:31
by DiscoFreq
The prices vary a lot, I've seen them for around 100 but also 200. Usually they are sold cheap when I don't look at them the last day or when I didn't bid, grrrr :)
I think I'll have to buy me an electrical screwdriver, put the camera on a stand, put some white paper or sheet on the floor and have a big "gutshot day" so analogguru can reply to my posts without mentioning gutshots :p
PostPosted: 29 Jul 2008, 10:57
by Bernardduur
Wow
That mod did the trick really well. Now the unit is silent and the only hum I hear is from my single coils.
Awesome!
PostPosted: 25 Jan 2009, 22:16
by fotoplastikon
Hey,
I've bought this delay as a broken some time ago.
Previous owner made strange connections inside and it seems that some of wires are connected in wrong places.
Is there any chance to get detailed inside photos of this unit including wires connections?
Thank you in advance!:)
PostPosted: 12 Feb 2009, 15:44
by lohstah
i returned to this effect to solve my "last" mystery:
when i put the switch on "chorus" or "duplex" setting and choose shorter delay times, i get a noticeable amount of distortion. what gives ?
i get 13.5 V out of the zener/trannie arrangement.
searching for different settings for the bbd bias did not help, it is good as it is set...also the clock trim is ok.
in the delay setting, the sound is perfectly ok. :scratch:
btw, what does that third trimpot do (the 220k near the fet that goes to ground) ?
cheers,
lohstah
Re:
PostPosted: 13 Feb 2009, 11:26
by borislavgajic
analogguru wrote:If you can wait.... I have one.... somewhere I even have the schematic tracing too. A nice delay with a special feedback feature, but sadly without a compander.
Dirk Hendrik may also have one ?
please, I would like to see schematic....if it is possible :block:
and is there version of MN3005 in small DIL8 package(like TL082).....or it have to be long BBD body(in one place they are selling them, but on picture there is normal DIL8 ic)???
thanks
boris
PostPosted: 13 Feb 2009, 11:53
by Dirk_Hendrik
It was on page 2 of this thread. Unfortunately Bernardduur seems to have the nasty habit of taking things down..
Yo Rogier!
gooi dat schema weer es effe naar boveh wil je!
PostPosted: 13 Feb 2009, 15:42
by lohstah
it is one of the big mn3005 er´s, with the space in between the pins.
i still have that schematic saved, i don´t know if it was the last version; if it´s ok with bernarddur, i can put it up as an attachment.
cheers,
lohstah
PostPosted: 14 Feb 2009, 08:42
by borislavgajic
lohstah wrote:it is one of the big mn3005 er´s, with the space in between the pins.
cheers,
lohstah
it would be great if yo attach it here!
thanks
boris
P.S. what is the best analog delay (MN3005) that I could build???
PostPosted: 14 Feb 2009, 11:25
by Bernardduur
Dirk_Hendrik wrote:It was on page 2 of this thread. Unfortunately Bernardduur seems to have the nasty habit of taking things down..
Yo Rogier!
Woops, grote schoonmaak hier
(on a big cleaning spree; schematic will be up soon!)
Enjoy the schematic
PostPosted: 14 Feb 2009, 11:50
by Dirk_Hendrik
Thanks!!!
PostPosted: 14 Feb 2009, 20:14
by borislavgajic
:thumbsup thank you very much
boris
p.s.
so what build is my next..this , or "aqua pussy"???......
PostPosted: 15 Feb 2009, 16:36
by lohstah
apart from the happiness that the schematic is up again and the questions of what to build next, does anybody have an idea what´s causing the trouble with my pearl ? :wink:
cheers,
lohstah
PostPosted: 20 Feb 2009, 20:31
by lohstah
update on my pearl woes: also the short delays are distorted. not only in the chorus settings, but also in the pure dealy setting.
so, what can cause distortion in short delays, the shorter, the more distorted, while long delays are perfectly ok ?
it´s not the mn3005, i tried another one and the trouble stays the same.
cheers,
lohstah
PostPosted: 09 May 2010, 02:58
by professor plum
hey guys, i was just wondering if anyone knew the approximate delay time on this thing? thanks!
PostPosted: 09 May 2010, 22:32
by Dan N
I would guess it's in the same neighborhood as other mn3005 based delays- 500 to 600ms of clean delay? Think DM-2 and AD-80 time amounts.
PostPosted: 09 May 2010, 22:42
by Scruffie
Each MN3005 only delivers around 300ms of Delay (204.8ms according to the datasheet but that doens't mean it can't be pushed further) and as far as I can see this only has a single chip so that much.
