Dr.Z For All
Dr.Z For All
Postby invalidcd » 27 Jul 2008, 06:00
I have drawn up schematics for Mazerati-GT, Stangray ,and Mini Z , so i decided to make a zip-file of all the known Z layouts and schematics.
Enjoy :D http://www.mediafire.com/?en4cmeen41o
For this message the author invalidcd has received thanks: 12
bmxguitarsbmx (15 Mar 2017, 04:12), darkbluemurder (29 Jan 2014, 13:23), delus (15 Nov 2011, 16:50), Fredenando (29 Oct 2011, 02:10), Intripped (08 Dec 2013, 23:01), morbidalex666 (16 Sep 2012, 14:55), Peamiller (23 Mar 2011, 22:25), sinner (20 Nov 2012, 23:20), timbo_93631 (15 Mar 2011, 20:30), tschrama (28 Oct 2011, 18:13) and 2 more users
invalidcd
Have thanks: 13 times
Re: Dr.Z For All
Postby drumslinger » 27 Jul 2008, 06:45
SWEET!
drumslinger
Re: Dr.Z For All
Postby RnFR » 27 Jul 2008, 14:09
now thats just awesome.
Has thanked: 150 times
Have thanks: 174 times
Re: Dr.Z For All
Postby gnognofasciani » 27 Jul 2008, 14:33
Thanks! :applause:
Search button is your friend
gnognofasciani
Have thanks: 11 times
Re: Dr.Z For All
Postby briggs » 27 Jul 2008, 22:49
RnFR wrote:now thats just awesome.
+1
I am Klon.
briggs
Has thanked: 30 times
Have thanks: 124 times
Re: Dr.Z For All
Postby guilds100 » 29 Jul 2008, 17:54
Thannk you. Thank you.
guilds100
Re: Dr.Z For All
Postby briggs » 30 Jul 2008, 09:15
I really like the look of the Carmen Ghai's tone control setup. I think I might give it a try :-)
I am Klon.
briggs
Re: Dr.Z For All
Postby AL » 30 Jul 2008, 16:48
I can't seem to download these. It says I need a supported browser. Do I need to get an account for this?
And thank you for the work on the schems. :applause:
*Edit* Got it downloaded. Thanks
AL
AL
Re: Dr.Z For All
Postby klingo » 02 Aug 2008, 18:21
briggs wrote:I really like the look of the Carmen Ghai's tone control setup. I think I might give it a try :-)
this tone control is great but you must know it's a mid scooper and not a low loss one.
personnaly i like to insert a 47KA pot/trim between the 10nf and ground that let me dial the amount of mid-scoop/gain-drop. of course with this pot/trim maxed the tone control is less effective but restored mids sound better for distortion IMHO.
last thing, if it work backward your wiring is correct :wink:
klingo
Re: Dr.Z For All
Postby fluzo » 04 Aug 2008, 18:17
Thank you.
Does anybody know the Route 66 transformer specs? OT primary impedance in particular.
fluzo
Re: Dr.Z For All
Postby invalidcd » 04 Aug 2008, 18:52
fluzo wrote:Thank you.
I think its a 4k ultra linear.
invalidcd
Re: Dr.Z For All
Postby islandamp » 05 Aug 2008, 07:52
Has anyone drawn up a schematic for the Prescription jr. yet?
islandamp
Re: Dr.Z For All
Postby fluzo » 05 Aug 2008, 12:07
Thanks. Why ultralinear? On the schematic it looks like normal push-pull operation...
fluzo
Re: Dr.Z For All
Postby klingo » 05 Aug 2008, 19:06
fluzo wrote:Thanks. Why ultralinear? On the schematic it looks like normal push-pull operation...
no screen choke or resistor supply, KT66 screens are connected to a tap at the output transformer (43%). so it is ultralinear. the MOV/genalex datasheet is showing a 8K OT (with higher voltage) . i don't know what the good Dr use in it, but 6K6 and 8K OT seem common with KT66.
http://www.drtube.com/datasheets/kt66-mov77.pdf
klingo
Re: Dr.Z For All
Postby fluzo » 06 Aug 2008, 19:09
Thank you klingo
fluzo
Re: Dr.Z For All
Postby chicago_mike » 11 Aug 2008, 18:15
I havent seen a Route 66 schematic yet, but I keep thinking its gotta be an old mullard circuit.
You look in the mullard amp circuit book, theres a Ef86, and 2 kt66 amp that just seems to scream the route 66 to me...
I could just be really goofy too. :block:
Skyline FX 2013
chicago_mike
Has thanked: 23 times
Have thanks: 282 times
Re: Dr.Z For All
Postby klingo » 12 Aug 2008, 21:22
nothing new.
OK rt66 tone stack is cool.
klingo
Re: Dr.Z For All
Postby shicky » 29 Aug 2008, 18:21
Hi, I am trying to build mini z for my first tube amp project.
I have a few questions.
1. It was impossible for me to get 40uF 450V and 20uF 450V capacitors used in Rectifier (Bridge?) section.
I was able to get 47uF 450V and 22uF 450V.
Values didn't really make a huge difference in PSU Designer graph but I would like to make sure if I can use those.
2. What should I use for Rectifier Diodes, 1N4001?
3. What would be the fuse size? is 1A sufficient?
I would really appreciate your help.
- shicky -
shicky
Re: Dr.Z For All
Postby tunghaichuan » 29 Aug 2008, 18:31
shicky wrote:Hi, I am trying to build mini z for my first tube amp project.
They will be fine. Caps are usually 20% unless marked differently, so a few uF won't make that much difference, if any.
shicky wrote:2. What should I use for Rectifier Diodes, 1N4001?
I'd use 1N4007s, rated for 1A, 1000V.
shicky wrote:3. What would be the fuse size? is 1A sufficient?
[/quote]
Not sure, I usually use 2A fuses in builds of this power level.
tung
tunghaichuan
Have thanks: 3 times
Re: Dr.Z For All
Postby fluzo » 11 Sep 2008, 17:24
I have tried the Route 66 BASS + TREBLE eq in my EF86 amp and it doesn't suck tone.
Any ideas on how to make the treble control more "trebley"? The bass pot works fine but the treble pot is a bit dark to my ears...
Thanks for your help.
fluzo
Next
Return to Amplifiers
Users browsing this forum: No registered users and 16 guests
