Lunevibe - A Tremulus Lune / Magnavibe mash-up
Postby Nocentelli » 18 Feb 2012, 19:03
The audio section from the Magnavibe driven by an LFO derived from the Tremulus Lune, with vibrato/tremelo switch. Sounds great: Any suggestions for improvements are more than welcome (bear in mind I'm trying to keep it simple-ish!). A vero layout to follow when I've got it verified:
For this message the author Nocentelli has received thanks: 12
bamwels (13 Mar 2012, 19:23), DarkRain (20 Feb 2012, 11:08), IvIark (18 Feb 2012, 23:58), jimini (19 Feb 2012, 23:19), jrod (20 Feb 2012, 15:17), KindaFuzzy (18 Feb 2012, 20:49), rocklander (19 Feb 2012, 23:26), roseblood11 (19 Feb 2012, 23:07), sinner (19 Feb 2012, 22:00), teleK (19 Feb 2012, 00:57) and 2 more users
Nocentelli
Has thanked: 889 times
Have thanks: 853 times
Re: Lunevibe - A Tremulus Lune / Magnavibe mash-up
Postby Nocentelli » 19 Feb 2012, 21:58
It works:
For this message the author Nocentelli has received thanks: 8
dbat69 (17 Mar 2014, 10:55), GuitarlCarl (23 Feb 2012, 02:22), joe_pineapple (07 Mar 2012, 08:24), jrod (20 Feb 2012, 15:17), kaycee (20 Feb 2012, 18:20), millibobs (26 Apr 2019, 13:58), rocklander (19 Feb 2012, 23:26), sinner (19 Feb 2012, 22:00)
Nocentelli
Postby briggs » 19 Feb 2012, 22:25
That looks pretty cool. I like the versatility of the Trem Lune LFO, it's got a huge range of usable settings..
I am Klon.
briggs
Has thanked: 30 times
Have thanks: 124 times
Postby kaycee » 20 Feb 2012, 18:16
Funny, I tried the same idea - but didn't like it myself. Also with a couple of other LFO's but nothing sounded quite as good as the original, granted its got limited controls, but it sounds so nice 8)
My stock one built using your vero, lovin it - thanks for the layout 8)
For this message the author kaycee has received thanks:
Nocentelli (20 Feb 2012, 20:08)
kaycee
Has thanked: 31 times
Have thanks: 13 times
Postby Nocentelli » 20 Feb 2012, 20:11
Great looking pedal! Couple of questions - What's that finish? Did you buy the box like that, or paint it yourself? And what is that cool-looking LED/LED cover?
Nocentelli
Postby kaycee » 20 Feb 2012, 21:15
Thanks for the kind words mate!
Yes, hand painted with the quick dry enamel paints you can get in Homebase or B&Q in the little pots, Polyvine is the make. The colour is Antique Bronze, some stick on letters from a craft shop and a couple of coats of paint on clear and Roberts yer Dad's brother :wink:
The LED cover is called a 'Fensell' lense, you pop an LED inside, got it from Maplins I think.
Built a couple from your layouts, appreciate you sharing them :thumbsup
kaycee
Postby Nocentelli » 20 Feb 2012, 21:17
You're welcome... Fresnel lens, so that's what they look like. I'm always on the look out for LED mounts, don't really like the usual DIY bezels you get. I used to just have them poking through the box a la frequency central, but I can't get them to stay put.
Nocentelli
Postby millibobs » 24 Apr 2019, 17:55
Hi Folks
Built took a second attempt at this and can now get signal but LED on board does not light. Also getting loud popping when I flip the SPDT. Speaking of the switch, is this a simple on/on or should it be on/off/on or something else?
It's not a complex circuit and I've checked all the component placings/jumpers and it all seems ok.
Also checked off-board wiring and all seems fine.
The cuts on the board are hard tyo make out in some instances because some of them are hidden behind components - there is no separate page for just cuts. Really keen to finish this and make it work - the OCD is strong in me..............
Hope somebody picks this message up.......
David
millibobs
