DR. L3CT3R - Based on Laboga Mr.Hector High Gain Preamp
- J0K3RX
- Degoop Doctor
Ok, I love how these amps sound so I made this jfet/mosfet preamp from the good old Russian schematic... I have not tested it, yet. Pretty sure it will work! Look it over and see if you can find any mistakes?
Here is the real amp demo from Ola
Say hello to DR. L3CT3R - Named after one of my favorite characters, Dr. Hannibal (The Cannibal) Lecter
Transfer... if you dare!
A pedal maker once tried to test me. I ate his liver with some fava beans and a nice chianti.
https://dl.dropboxusercontent.com/u/111 ... R/DL-1.pdf
Large layout image
https://dl.dropboxusercontent.com/u/111 ... R/DL-1.PNG
Large layout image
- J0K3RX
- Degoop Doctor
There were a couple mistakes on my first layout... This layout is 100% verified! And sounds killer to! No unwanted noise either, just killer high gain and brutal tone!
https://dl.dropboxusercontent.com/u/111 ... rified.PNG
layout
https://dl.dropboxusercontent.com/u/111 ... RIFIED.pdf
layout
- J0K3RX
- Degoop Doctor
Here is a quick chunk demo DR.L3CT3R just to show the function of the "sweep" pot.. I am playing and turning the sweep pot a little bit as I go. This obviously has no musical value what so ever, just to show what effect the sweep pot has... I am using 7 string guitar with passive stock pickups > DR.L3CT3R pedal > Lart - simple cab sim > into the computer with a tone port GX > into Reaper with a small bit of 275ms delay. No other processing other than the delay...
https://dl.dropboxusercontent.com/u/111 ... L3CT3R.mp3
- Manfred
- Has thanked: 1671 times
- Been thanked: 1344 times
The layout looks like created in Abacom SprintLayout.
May you share the SprintLayout file?
I would appreciate it very much.
- J0K3RX
- Degoop Doctor
elkulon wrote:Nice, work, J0K3RX!!!
As usual, I will build/test it as soon as I could...
Question...
How did you based the original scheme to "translate" it to JFET/MOSFET version???
I didn't create the original schematic... OldMike and Anton Kalina at www.GTLab.net
Look here..
http://gtlab.net/gtlab4/archives/category/fet_projects
By the way, I don't like the VHT at all but the Laboga (Mr.Hector) is gold!
Hello J0K3RX, the mp3 file is no longer, could you explain the function of the sweep potentiometer? Thank you!!
J0K3RX wrote:Here is a quick chunk demo DR.L3CT3R just to show the function of the "sweep" pot.. I am playing and turning the sweep pot a little bit as I go. This obviously has no musical value what so ever, just to show what effect the sweep pot has... I am using 7 string guitar with passive stock pickups > DR.L3CT3R pedal > Lart - simple cab sim > into the computer with a tone port GX > into Reaper with a small bit of 275ms delay. No other processing other than the delay...
- lead2203
The sweep pot is just changing the mixing resistor in the tone stack. I found this thread that still has the schematics up so that may help you with this circuit.
http://guitar-fx-layouts.42897.x6.nabbl ... 14828.html
