Midi Switcher - Using Arduino
Postby the_ungod » 07 May 2019, 17:48
Hi guys,
After searching around for already build modules, for a looper / switcher i came across this project:
https://www.jimkim.de/guitar-projects/a ... di-switch/
I was thinks in connecting that to this:
https://www.aliexpress.com/item/4-chann ... st=ae803_4
My only concern is about noise... what are your thoughts about it?
the_ungod
Have thanks: 7 times
Re: Midi Switcher - Using Arduino
Postby plush » 07 May 2019, 21:11
SPDT relay for a loop switcher is no bueno.
plush
Has thanked: 29 times
Have thanks: 82 times
Postby the_ungod » 08 May 2019, 00:03
plush wrote:SPDT relay for a loop switcher is no bueno.
Already heard that...already working on an alternative...
the_ungod
Postby the_ungod » 08 May 2019, 00:05
So far...
Please comment...
the_ungod
Postby roseblood11 » 08 May 2019, 01:55
roseblood11
Has thanked: 353 times
Have thanks: 318 times
Postby kusi » 08 May 2019, 07:09
the_ungod wrote:So far...
Please comment...
what optocoupler do you use? R2 seems way to high, i use 470R - 1k for a 6N138. for R3 i use 10k
R6 R7 also too high, probably copy/paste
add 100nF to the psu-pins of the inverter, and tie the unused inputs of the inverter gate to GND.
can't comment on the arduino circuit.
kusi
Have thanks: 46 times
Postby the_ungod » 08 May 2019, 12:15
roseblood11 wrote:https://www.uk-electronic.de/onlineshop/index.php?cPath=105_348&language=en
https://musikding.rocks/wbb/index.php/T ... /?pageNo=1
Thanks...i already know those (expensive) options....lol
the_ungod
Postby the_ungod » 08 May 2019, 12:21
Please comment...
what optocoupler do you use? - 6N138
R2 seems way to high, i use 470R - 1k for a 6N138. - my error, already fixed
for R3 i use 10k - In the original schematic (jimkin) its a 1k, i've done some research and found (https://cdn.instructables.com/FHN/J43V/ ... .LARGE.jpg) another schematics who use 10k... i've changed that to 10k
add 100nF to the psu-pins of the inverter, and tie the unused inputs of the inverter gate to GND. - can you explain a bit of this?
the_ungod
Postby plush » 08 May 2019, 12:34
the_ungod wrote:add 100nF to the psu-pins of the inverter, and tie the unused inputs of the inverter gate to GND. - can you explain a bit of this?
Cap between vcc and gnd, placed near the chip, provides low impedance power path and also filters some interference and ripple. In some cases it is mandatory. In others - just a good design practice.
Connecting unused inputs/outputs of opamps, inverters and other ICs to ground (or to vcc, vee, vbias) is a common technique, helps to prevent self oscillations, unstable behavior and other stuff. It is specified in the datasheed for the particular part.
Read your datasheets. (p.10. and p.11.1)
:horsey:
For this message the author plush has received thanks:
the_ungod (08 May 2019, 14:25)
plush
Postby the_ungod » 08 May 2019, 14:26
Updated (including the commented changes
And now the PSU
the_ungod
Postby Fender3D » 08 May 2019, 14:35
If you connect both input AND output to GND you will likely kill that poor 74LS14.....
Just connect input to GND and leave output floating unconnected
For this message the author Fender3D has received thanks: 2
kusi (08 May 2019, 14:58), the_ungod (08 May 2019, 15:13)
Fender3D
Has thanked: 105 times
Have thanks: 140 times
Postby the_ungod » 08 May 2019, 15:14
Thanks for the comments...
New update
Arduino Board
PSU
Relay Board
the_ungod
Postby Fender3D » 08 May 2019, 16:38
Nice...
What's IC2? Check it can supply the current load, I would use a transistor buffer, just in case
Again, it's common practice to use a flyback diode in parallel with the relais coil to eliminate the sudden voltage spike
Fender3D
Postby the_ungod » 08 May 2019, 16:55
Fender3D wrote:Nice...
The IC2 is a unl2803 - it allows 500ma in each output acording to the datasheet
Flyback diode - forgot about that, gonna update
the_ungod
Postby the_ungod » 08 May 2019, 18:44
One of the features i would like to implement its a On/Off/Auto switch for each effect
I draw this sketch... what do you think?
the_ungod
Postby Fender3D » 08 May 2019, 23:20
well.... that's an On\Auto switch.
I used an On\Off\On toggle switch when I put my pedals in a rack enclosure 30 years ago to achieve the On\Off\Auto modes. I did it the very next day I forgot the switches unit at home and I had to hardwire some relays to play....
But that was just to use the unit manually just in case I would forget the switch unit again, if you wanna use a footswitch so you can switch on and off your loops, you'd better use some momentary switches connected to Arduino's inputs and write a proper code.
PS
I wouldn't bother about LEDs
Fender3D
Postby the_ungod » 08 May 2019, 23:50
Fender3D wrote:well.... that's an On\Auto switch.
PS
Hi Fender3D
Thanks for your comments
The whole idea is to make a 2U rack with all the pedals and switching system inside.
The value of the on/off/auto is the following:
On - practice pedal combinations without having to program a patch
Off - eliminate a pedal (faulty one or whatever) on the fly, without programming
Auto - to normaly use the switching system
The LED are there just for warning. Imagine i program a patch with a clean sound and test it adding a "on" fuzz... then i forget to put the toggle switch on the auto position...just in case
Or by mistake i put a pedal in off mode...
This way i have a instant visual sight of the pedals on off or auto mode.
the_ungod
Postby kusi » 09 May 2019, 06:56
no need for a flyback diode on the ULN2803, it's already included in the chip, connect pin10 to +5V and you are done (like you already did in the first schematic)
kusi
Postby Ripthorn » 09 May 2019, 09:25
I posted a project in the ready to build section complete with schematics, layout, code, etc. Uses an arduino nano and controls 5 loops.
Exact Science is Not an Exact Science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
Ripthorn
Have thanks: 6 times
Postby the_ungod » 09 May 2019, 10:14
Yes, in the auto mode its ok, but in the "manual mode" the IC2 is bypassed and the relay is connected to ground.
the_ungod
Next
Users browsing this forum: No registered users and 6 guests
