TC Electronic - MojoMojo
Postby KindlyKiller » 25 Sep 2011, 07:58
Stupid name, I know - but listen to it.
Link
KindlyKiller
Re: TC MojoMojo
Postby IsakaJr » 22 Oct 2012, 01:53
SOunds like.... Looks like..... A TIMMY!!!! :horsey:
IsakaJr
Re: TC MojoMojo
Postby Lucifer » 22 Oct 2012, 22:47
The MojoMojo's a tasty sounding pedal - and one of the few that I've wanted to get my hands on.
Anyone got one 'undressed' yet ? :twisted:
Lucifer
Has thanked: 104 times
Have thanks: 95 times
Re: TC MojoMojo
Postby bancika » 04 Mar 2013, 00:55
I'd like to see it too. Considering buying one since I'm on the market for mild-ish transparent, open sounding pedal. Kinda opposite of TS :)
bancika
Has thanked: 16 times
Have thanks: 86 times
Re: TC MojoMojo
Postby ct88 » 27 Sep 2015, 22:03
i have it, tell me if some1 is still interested, i'm gonna try to unmount the pcb from the schassis
BTW, right now is only 49euros here in Europe, you can finally buy it easily
ct
ct88
Have thanks: 9 times
Re: TC MojoMojo
Postby roseblood11 » 27 Sep 2015, 23:04
Sure, I guess it's a Timmy clone, but who knows?
roseblood11
Has thanked: 348 times
Have thanks: 310 times
Re: TC MojoMojo
Postby clintrubber » 28 Sep 2015, 08:22
roseblood11 wrote:Sure, I guess it's a Timmy clone, but who knows?
No, different (more elaborate) circuit.
I like it (at least for the EU49 :lol: ), but would have liked to have some more clean boost available.
clintrubber
Has thanked: 13 times
Have thanks: 2 times
Re: TC MojoMojo
Postby okgb » 01 Oct 2015, 03:03
Curious too , I saw one for a good price but no reference what it may have been based on.
okgb
Has thanked: 199 times
Have thanks: 41 times
Re: TC MojoMojo
Postby clintrubber » 01 Oct 2015, 09:51
okgb wrote:but no reference what it may have been based on.
I thought it's some EQ-shaping, a clipping stage & a Baxandall-type EQ-section.
I thought the schematic was out somewhere, but that might have been the brother-pedal (Dark Matter)
Bye
clintrubber
Re: TC MojoMojo
Postby FeVeR2112 » 24 Feb 2018, 04:09
Anyone still interested in this pedal? I will have one in the shop soon...
FeVeR2112
Has thanked: 20 times
Have thanks: 34 times
Re: TC MojoMojo
Postby caspercody » 24 Feb 2018, 06:38
Yes. very interested.
caspercody
Has thanked: 30 times
Have thanks: 44 times
Re: TC MojoMojo
Postby Chugs » 24 Feb 2018, 09:43
Possibly similar topology to the Dark Matter but with different values?
Chugs
Has thanked: 59 times
Have thanks: 49 times
Re: TC MojoMojo
Postby clintrubber » 24 Feb 2018, 14:45
Chugs wrote:Possibly similar topology to the Dark Matter but with different values?
Could very well be. Thought I'd seen the DM-sch long ago, but don't recall the details. Thought it was in low-res as well.
Always nice to know how it's doing it's thing (/mojo)
Unrelated, the MojoMojo has for now left the board. I was better served by a clean boost, which the MojoMojo doesn't really do (but in all fairness, I don't blame it for that)
clintrubber
Re: TC MojoMojo
Postby Chugs » 24 Feb 2018, 14:58
Dark Matter Schematic is here. Possibly uses the same board as the Mojo Mojo with different values and/or a few different parts. There are unused parts places on the Dark Matter boards.
viewtopic.php?f=1&t=16220&p=260813&hilit=dark+matter#p260813
Chugs
Re: TC MojoMojo
Postby clintrubber » 24 Feb 2018, 15:55
Thanks, that'll indeed be the spot were I saw it.
Bye
clintrubber
Re: TC MojoMojo
Postby FeVeR2112 » 28 Feb 2018, 19:52
Just received the unit from a local. I will setup for hi-res gut shots - it is all chicklette parts so caps will be a problem to figure out but I will do an in-situ measure.
First pictures show an interesting case design with a contact switch for when it it opened.
More to come.
For this message the author FeVeR2112 has received thanks: 5
caspercody (28 Feb 2018, 20:41), clintrubber (28 Feb 2018, 21:52), modman (19 Mar 2018, 15:04), mr coffee (11 Mar 2018, 08:29), okgb (12 Nov 2018, 20:53)
FeVeR2112
Re: TC MojoMojo
Postby Ice-9 » 28 Feb 2018, 20:53
Looks pretty similar to the internals of the TC Dark Matter pedal, it has the same opto bypass setup as well. You may fid the trace easier if you check out the schematic for the dark matter pedal.
The contact switch you refer to when opening the case is just a grounding tag.
Ice-9
Has thanked: 141 times
Have thanks: 361 times
Re: TC MojoMojo
Postby FeVeR2112 » 01 Mar 2018, 06:35
I noted several component areas unpopulated. Likely a common circuit board that can do multiple pedals. I will put it under the microscope this weekend.
For this message the author FeVeR2112 has received thanks: 3
caspercody (01 Mar 2018, 18:06), clintrubber (01 Mar 2018, 15:17), mr coffee (11 Mar 2018, 08:29)
FeVeR2112
Re: TC MojoMojo
Postby caspercody » 13 Mar 2018, 15:15
Just wanted to see if any updates on this one?
caspercody
Re: TC MojoMojo
Postby FeVeR2112 » 14 Mar 2018, 16:46
I have been swamped with work and a crappy flu.... it will be a week or two yet.... sorry :(
FeVeR2112
Next
Users browsing this forum: OC26, snofla1900 and 11 guests
